Rally wheels for 1982 delta 88 royale coupe
Would like to know if i could put rally wheels on my 1982 delta 88 royale coupe,size,bolt pattern etc. New to forum and found some informative stuff on this site. Thanx.
Yes, although it's necessary to find out what bolt circle (5 on 4.75" or 5 on 5") you have. The easiest way to determine the bolt circle is to look at the lug nuts. If your o.e. lug nuts are 3/4'' o.d., then you have a 5 on 4.75 bolt circle. If the lug nuts are 13/16", then you have a 5 on 5 bolt circle. The rallye II wheels were made in both bolt circles.
Ooops, I stand corrected. I must be losing it. Joe is correct the Rallye II wheel is a Pontiac wheel, and although they will fit your Olds, the centercaps would need to be adjusted to show something other than a Pontiac emblem. Thanks for catching that Joe.
82olds88rayale
October 12th, 2009 07:57 PM
