Body Off? 66 cutlass
Old April 18th, 2023, 12:02 PM
66gutlass's Avatar
Hey all! How does a guy go about lifting the body off the frame. Decided I want to go the full nine yards as I am practically there already, and waiting for motor work anyways. Just need it up enough to work under and drop it again.
66gutlass is offline
Old April 18th, 2023, 03:14 PM
VI Cutty's Avatar
There are a number of ways depending on what space and tools you've got available. Check out some of the other body off threads here and you'll see many examples. Having a 2 post lift is the easiest route. Some people have used engine hoists, etc.
I built supports for my '70 using pressure treated 4x4 with 5/8" plywood gusseting. The legs were assembled but the cross members were left loose for installation. I determined some temporary jack points on the car's floor and trunk pan so I could create enough clearance to slide 4x4 through and support the body. My friend and I then used floor jacks on each side to raise the 4x4 to a height we could install the legs. Repeat for the other end. Then the frame was slid out - we made sure the legs were wide enough and cross members high enough for clearance. The front suspension had already been removed but the rear axle was still installed and we removed the tires.
If you're planning on removing undercoat and cleaning/repairing/painting the underside do yourself a BIG favour and get a rotisserie!
VI Cutty is offline
android 211
August 4th, 2022 10:04 AM
rocketscientis
October 1st, 2019 06:42 AM
joes66olds
April 4th, 2017 02:48 PM
scubastever
October 23rd, 2015 01:21 PM
raw442
September 30th, 2012 01:57 PM
Quick Reply: Body Off? 66 cutlass
