Body mount frame repair
Old April 24th, 2021, 09:02 AM
Chatt's Avatar
I've searched a lot of threads and utubes and all repairs of mounting holes are cut out and new repairs welded flush. Is there some that weld washers on top of frame? That would , I'm sure, meen all mounts would have to repaired to keep it level. Sure, I'm lazy but willing to do correct repairs. Thanks
Chatt is offline
Old April 24th, 2021, 04:00 PM
Run to Rund's Avatar
If your frame is corroded, it might be best to search for a nice desert southwest frame. What year do you need?
Run to Rund is offline
Old April 25th, 2021, 10:13 AM
Chatt's Avatar
It's a '69' convertible. Come on,,,, Give me the 'Good, Bad, and Ugly'. Is there something wrong about welding repair washers to top of frame????
Chatt is offline
Old April 25th, 2021, 11:38 AM
No it's not a parts car!!
Schne442's Avatar
I am by no means a Restoration expert, I can only give my opinion on how I repaired my 72 Cutlass convertible frame
I had 7 frame mount holes that were rusted and needed repair. I bought a couple washers for this but found the metal was too thin and the washers wouldn't cover the entire area.
I decided to weld in new metal and recut the holes, If you look at my Photo Album you can see my process.
I would think if you want to just weld new washers on top, your call, but as you mention, to keep it all level you would have to do them all and unless you remove all of the
rust it would just come back and you would be in the same boat
Good Luck
Schne442 is offline
Old April 25th, 2021, 11:57 AM
Oldsmaniac's Avatar
Do you mean like this/ Worked for me on my 67 Cutlass.
Oldsmaniac is offline
Old April 25th, 2021, 01:24 PM
Schne442's Avatar
Here are a few pictures before and after, For comparison
Schne442 is offline
Old April 28th, 2021, 10:05 AM
Chatt's Avatar
Well I’m into it
Chatt is offline
Old April 28th, 2021, 10:10 AM
Chatt's Avatar
See anything I need to focus on ?
Chatt is offline
Old April 28th, 2021, 02:46 PM
Just that mess on the floor...
oldcutlass is online now
Old April 29th, 2021, 09:05 AM
Chatt's Avatar
Heh Heh Heh!!!! After I took pictures I realized what a mess I was working above. I'll be better when I get started on the right side. Learning a lot about grinding and spot weld removing
Chatt is offline
Old December 31st, 2022, 09:06 AM
Chatt's Avatar
end of year progress
Whew!!!!
Chatt is offline
Old January 22nd, 2023, 01:27 PM
Chatt's Avatar
Still at it!
Frame all painted, diff. gears and axles installed, CPP disc brakes on. Now me and QA1 get to play!
Chatt is offline
DHolmes
October 27th, 2020 09:18 AM
tkcutlass
August 16th, 2020 08:47 PM
Eric De Guzman
Body work
April 2nd, 2019 02:56 PM
Carsick
30
December 10th, 2015 07:33 PM
foo
June 28th, 2012 11:00 AM
Quick Reply: Body mount frame repair
