Compatible Wiring Harness for 1970 Oldsmobile 98
Old March 23rd, 2024, 10:41 PM
'70 Olds 98 Ambulance
Dialswiftjustice's Avatar
Hey there is anybody happen to know if there is a wiring harness that is compatible from any other Oldsmobile model for a 1970 Oldsmobile 98? Got a lot of destroyed wires due to rodents it's pretty extensive. I'd like to get a harness already ready to go but I'm curious to see if one would work from maybe a Cutlass or an 88?
Thanks for the advice!
Dialswiftjustice is offline
Old March 24th, 2024, 05:58 AM
There are TWO "forward harnesses", the engine harness and the forward lamp harness. Olds Ninety Eight and Delta 88 use the same underhood harnesses, but the forward lamp harness may differ depending on cornering lights or not. 1969 is not exactly the same as 1970, since the 1970 engine harness has the TCS wiring. Also note that they may not be the same for other reasons. I found this out the hard way on a 442. The wires were the same but their positions in the firewall connector were not. Cutlass harnesses do not interchange.
joe_padavano is online now
Old March 24th, 2024, 12:04 PM
Have you tried repairing the existing wiring harness?
Olds64 is online now
Pesaroma
Ninety-Eight
February 29th, 2024 08:47 AM
beny0870
June 18th, 2017 09:32 PM
Timberice
August 16th, 2014 09:46 AM
mycut
August 25th, 2010 07:49 AM
Olds64
October 3rd, 2007 05:34 AM
Quick Reply: Compatible Wiring Harness for 1970 Oldsmobile 98
