Light switch
Old March 19th, 2024, 03:30 PM
Chuxter's Avatar
Light switch
So what is the easiest way to get to the back of the light switch to change it out for a new one?
Chuxter is offline
Old March 19th, 2024, 03:44 PM
'72 Cutlass ragtop
70sgeek's Avatar
Vehicle?
70sgeek is offline
Old March 19th, 2024, 06:17 PM
Chuxter's Avatar
my bad again. 1970 cutlass supreme
Chuxter is offline
Old March 19th, 2024, 06:59 PM
'72 Cutlass ragtop
70sgeek's Avatar
The headlight switch dash bezel is threaded from the outside of the dash into the switch which it secures behind the dash - behind the dash, the top of the switch body has a spring-loaded button that has to be pushed down to release the pull lever. You have to pull the lever out of the switch before the switch unit itself can be removed from the dash.
ideally you want to hold the switch body with one hand while you unscrew the bezel with the other. Some gymnastics may be required but it's not difficult
The switch body can be accessed from either underneath the dash or from the top if you take out the left-most gauge pod (brake/oil/gen). To unscrew the switch bezel outside the dash, I use a needle-nose pliers with a bolt sandwiched in its jaws placed deep enough to space the plier ends out to catch the bezel grooves for unscrewing it. Be careful/go slow when unscrewing it - it's plastic and if you're not careful you can strip the threads.
Be careful also not to forget there's also a ground loop wire which mounts behind the dash ahead of the switch body (it sits between the switch and inside dash surface). So when reinstalling the new switch be sure it's reconnected.
recommend you disconnect the battery before removing the light switch.
70sgeek is offline
Old March 20th, 2024, 04:17 AM
Chuxter's Avatar
I have the gauge out but can't seem to find a way to get my hand to the switch. Thought there might be some trick to it I haven't figured out yet.
Chuxter is offline
Old March 20th, 2024, 06:22 AM
Have you released the **** from the switch? That has to be done first.
joe_padavano is online now
Old March 20th, 2024, 07:13 AM
'72 Cutlass ragtop
70sgeek's Avatar
Maybe unbolt and remove the driver-side dash a/c vent for extra clearance?
70sgeek is offline
Old March 20th, 2024, 08:32 AM
Chuxter's Avatar
I have read the articles on releasing the know from the switch and so forth. My problem is I can't seem to figure out how to get my hand to the switch. Removing the ductwork to the vent would allow me to get to it easier but it appears to be fastened to the dash and the bolt for it is above the switch. Planning on removing seat so i can get under the dash easier and seeing what I can do from there.
Chuxter is offline
Old March 20th, 2024, 09:48 AM
Lance
ROCKET VAPOR's Avatar
I have had good luck accessing the light switch by removing the left gauge.
ROCKET VAPOR is offline
Brakes/Hydraulic Systems
September 2nd, 2019 06:32 AM
53oldsmobile
July 12th, 2017 05:58 PM
navvet
December 6th, 2015 12:57 PM
dave marki
September 1st, 2015 10:43 AM
FirstClass 383
August 6th, 2013 06:17 PM
Quick Reply: Light switch
