Bolt help needed.
Old April 24th, 2024, 02:05 PM
Bgdaddy455's Avatar
Bolt help needed.
Trying to button up the 455 short block and am having issues locating the oil pump bolts. I looked at the threads in the main cap and it looks like they may be 5/16 fine thread. Does anyone know the grade, size, thread and length? ( I believe one is longer than the other). Also I need the same info for the bolts for the new pickup. The pump is a new melling HV pump and the pickup is matched to a 7 qt pan.
I also found the bolt I have pictured and can't for the life of me remember where it goes. Any help is greatly appreciated.
Bgdaddy455 is offline
Old April 24th, 2024, 03:05 PM
bccan's Avatar
The pictured bolt is the cam/uppr timing gear/fuel pump eccentric bolt. Not sure on the oil pump bolts.
bccan is online now
Old April 24th, 2024, 04:13 PM
Bgdaddy455's Avatar
Thank you, i bought a new roller cam and the new cam bolt has a roller on the end. I realized what it was about a half hour ago.
Old April 25th, 2024, 09:30 AM
Run to Rund's Avatar
Oil pump bolt threads are 3/8 x 16
Run to Rund is offline
kencpless@gmail.com
May 15th, 2022 09:33 AM
deaddds
April 28th, 2019 10:15 AM
CUT-N-UP
September 7th, 2013 08:24 PM
Redog
July 22nd, 2011 07:25 PM
silverriff
December 4th, 2008 01:51 PM
Quick Reply: Bolt help needed.
