1964 Cutlass pro touring build
Old September 22nd, 2021, 07:58 AM
72cuttys's Avatar
Picked up this 64 coupe on Sunday! Gonna be a longggg term project. I told my fiance 5 years but we'll see! Gonna be a ground up build. Car is pretty solid - needs a trunk pan and I found some rust behind a front fender. Blew off the front end yesterday, no big surprises. Just lots of missing bolts, etc. Plan is coilovers and tubular suspension on all 4 corners, big inch stroker LS with a 6 speed, interior will be mostly original with some comfy buckets. If anyone needs 64 parts, let me know! A lot of stuff isn't going back on.
72cuttys is offline
Old September 22nd, 2021, 09:33 AM
therobski's Avatar
and it's a POST CAR nice, very nice.
therobski is offline
Old September 22nd, 2021, 10:11 AM
mattking's Avatar
Looks great. Im sure i need parts but have no clue what yet. Ill be posting some more pics soon on my build thread, Im just going with a mild ls and muncie. But i did step up to a UMI suspension, and boxed the frame in. So far it is going together well
mattking is offline
Old September 22nd, 2021, 12:23 PM
72cuttys's Avatar
I Have UMI LS swap mounts in my 71 and like their customer service - so this will most likely get the UMI treatment as well. Going to be a 408ish ci LS with a t56 hopefully.
72cuttys is offline
Old September 22nd, 2021, 02:46 PM
oldsmoboogie's Avatar
I like it! It looks to be the same color combo as mine. It’s good to see a few 64 builds going on.
oldsmoboogie is online now
Old September 22nd, 2021, 03:39 PM
therobski's Avatar
Yes indeed! This was an experience.
Old September 23rd, 2021, 06:24 AM
mattking's Avatar
mine was red with white roof as well. Seems like a popluar combination
mattking is offline
Old September 23rd, 2021, 10:46 AM
72cuttys's Avatar
Its not staying red. Red is probably my least favorite color on a car(no offense). I'm a big fan of dark grays, I have been looking at Cyber gray from the C6 Z06. Hopefully I get some more time to work on the car this afternoon, I'd like to have all the stock suspension off the car.
72cuttys is offline
Old September 23rd, 2021, 11:07 AM
mattking's Avatar
Dont make the same mistake i just did. UMI (and others) say that on the bushings in the 64 axle housing you need to save the outer bushing shell to reuse for the poly bushing. I beat mine out with a hammer and of course the shells are now unusable
mines not staying red either... 40 ish year old me owes 16 year old me his dream car
mattking is offline
Old September 23rd, 2021, 12:28 PM
72cuttys's Avatar
The stock axle will not be staying in the car. The 64 will eventually get a stroked LS, so I will most likely build a 12 bolt or 9" to support it.
72cuttys is offline
Old September 24th, 2021, 12:59 PM
Jeff
Weezer's Avatar
Buick used a really nice graphite gray metallic on the Lacrosse's at the end of their production run. I hunted all over to find one, but couldn't. You should check that color out.
Weezer is offline
Old September 24th, 2021, 01:04 PM
NTXOlds's Avatar
Has anyone here seen a Juneau Gray Irid. in person? The few photos I have seen online look great, and it seems like an unusual color.
NTXOlds is offline
Old September 25th, 2021, 10:38 PM
Cmpeirce123's Avatar
I too am a fan of the greys on the 64. Mine will need a repaint in the future some time as it’s chipping in areas. Would like to go same color I have now or maybe a little darker. It’s a bluish grey color. I need to re do the rear quarters one day if I can ever find any. The bottom of the quarters were filled with mud at some point. Which is weird every where else they used metal.
Cmpeirce123 is offline
Old September 26th, 2021, 06:34 PM
72cuttys's Avatar
Beautiful 64! This will be a bit lower than that.
72cuttys is offline
Old September 27th, 2021, 05:11 PM
72 Olds CS
RetroRanger's Avatar
Beautiful 64! .
X2 that looks really nice
RetroRanger is offline
Old September 27th, 2021, 07:13 PM
thanks. It’s a 10 footer. Needs quarters, and a new paint job!
Old September 28th, 2021, 07:04 AM
72cuttys's Avatar
Pulled the front control arms off last night. Both nuts at the tops of the shocks rounded off, even after soaking in PB for days. Ended up lopping them off with the cutting wheel. Front end is almost torn down, then time to move to the rear and pull the axle and stock control arms.
72cuttys is offline
Old September 28th, 2021, 03:10 PM
Justin
oldstata's Avatar
Let me know if you want to sell the front hood lip trim.
oldstata is offline
Old September 30th, 2021, 09:16 AM
72cuttys's Avatar
Not sure if my hood has any trim on it? its missing the letters and the chrome center piece.
72cuttys is offline
Old October 3rd, 2021, 06:41 PM
72cuttys's Avatar
Just need to crawl under the dash and the front end will be torn down.
72cuttys is offline
Old August 29th, 2022, 07:51 AM
72cuttys's Avatar
Progress has been slow as my wife and I had a baby girl in March. I work on it here and there when time/funds allow. I ended up getting a new frame for it as this one had been pulled before and I wanted to start with a completely straight frame. Ended up getting a frame from under a 65 GTO that was replaced with an Art Morrison chassis. Frame got glass blasted then it then went to a good friend of mine to have a few body mounts repaired and also the HPI customs bracing kit installed.
72cuttys is offline
Old August 29th, 2022, 07:59 AM
72cuttys's Avatar
I also built a dolly from 4x4's with casters to put the body of the car on. I have a two car garage but the other bay is occupied by my 71 cutlass so I pushed the 64 body as close against the wall as I could and I have been building the frame between the two cars. Its tight, but its managable.
72cuttys is offline
Old August 29th, 2022, 08:03 AM
72cuttys's Avatar
More pictures of the frame work just to showcase my friends work. He can be found in IG at _smugmugchopshop_.
72cuttys is offline
Old August 29th, 2022, 08:52 AM
72cuttys's Avatar
Last week I finally got the chance to start mocking up some suspension. Full UMI with Viking coilovers and Speedway Tall 2" drop spindles. I have full proforged steering as well but I accidentally threw away my steering arms with the old spindles so I gotta order another pair. I want to mock up everything including brakes, gas lines, etc before I send the frame out to be powdercoated - I'd hate to have to drill through fresh powder coat for a bracket or something of the sort.
72cuttys is offline
Old August 31st, 2022, 07:46 AM
mattking's Avatar
It's looking really good. Nice welds for sure. I'll be really interested to see how the drop spindles work out. I could not get the trans mount to work with the external linkage on my Muncie, but I Bet you'll have better luck with the T56
mattking is offline
Old August 31st, 2022, 01:41 PM
72cuttys's Avatar
After talking to SST, i think i going to use a TKX instead. Not cutting the trans tunnel is a really big thing for me and of course there is a small price difference with the TKX being cheaper.
72cuttys is offline
Old August 31st, 2022, 02:18 PM
mattking's Avatar
I’m excited to hear that and see how it works out for you I’ve got just a regular tko in my truck but only have about 1 mile on it so far. I wanted to go tkx but just wasn’t ready to commit. It would open up a lot of clutch choices when paired to my ls block. The 10 spline in my Muncie limits options somewhat.
do you have a center console that you are planning to use?
mattking is offline
Old August 31st, 2022, 09:05 PM
rippinbyu's Avatar
Damn...that's impressive!
rippinbyu is offline
Old October 7th, 2022, 08:38 AM
72cuttys's Avatar
The picture doesnt do these things justice. These are the 12" rotor with 6 piston dynapros from Wilwood. By far the most I've ever spent on a set of brakes. Still need to do some measurements to make sure they are square to the rotor.
72cuttys is offline
Old January 26th, 2023, 12:39 PM
72cuttys's Avatar
Small update. Finished mocking the front suspension. Steering arms required a bit of modification as they were hitting the control arm stops before any real type of turning radius was achieved. Tore it all down and tossed it on the garage. Picked up a Quick Performance 9, all UMI rear suspension and viking coilovers. Waiting on custom coilover brackets from VFI for them to work with the rear.
72cuttys is offline
Old January 27th, 2023, 05:42 AM
  #31
dc2x4drvr's Avatar
Looking good..
dc2x4drvr is offline
Old January 27th, 2023, 07:05 AM
  #32
Cool to see the progress. Beautiful welds. Great welders are artists. 👍
no1oldsfan is offline
Old January 29th, 2023, 06:09 PM
  #33
72cuttys's Avatar
Custom rendering a fellow off the internet did for me.
72cuttys is offline
Old February 1st, 2023, 02:44 PM
  #34
Beautiful, I absolutely love that color!
Old February 2nd, 2023, 08:07 AM
  #35
72cuttys's Avatar
Thanks! Me too. Its a nissan color that came on the infamous R34 Skylines called Millennium jade.
So there is an issue with viking coilovers and the bracketry on Quick performance rears. The guy I ordered my rear suspension from makes his own brackets, and they finally came in. Gonna take them to powdercoat this weekend if I find some spare time.
72cuttys is offline
Old March 22nd, 2023, 09:46 PM
  #36
sean Buick 76's Avatar
Very cool project! That’s gonna rock! Nice work so far
Checkout Shadow Grey from a 1969 Acadian, that’s what I used on my Skylark and it’s amazing.
sean Buick 76 is offline
Old March 16th, 2024, 06:59 PM
  #37
72cuttys's Avatar
Been awhile since I updated this. The frame is completely done. Just need some wheels to roll it on. Body work going to start soon. I cut out all the bad sheet metal which didnt leave much - basically a shell. Ordered a bunch of metal today but a lot of what I need is out of stock through AMD. Had it blasted this week too.
72cuttys is offline
Old March 17th, 2024, 03:56 AM
  #38
Rallye469's Avatar
Wow!
Everything was bad? I hope you can keep that thing straight.
Rallye469 is online now
Old March 18th, 2024, 07:26 PM
  #39
72cuttys's Avatar
Wow!
floors bad, trunk bad, rockers bad, wheel wells bad. I have some 1x1" tube stock welded into it to keep it square.
72cuttys is offline
Old March 18th, 2024, 07:52 PM
  #40
72cuttys's Avatar
72cuttys is offline
Quick Reply: 1964 Cutlass pro touring build
