Window adj?
Old December 22nd, 2023, 06:18 AM
Chatt's Avatar
Window adj?
Window section is no where to be found in my manuals (3) . I have now ordered the Fisher Body manual. 69 olds cut vert. Hope it has it.
Chatt is offline
Old December 22nd, 2023, 11:07 AM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
Snap a pic of the misalignment.
Its not hard to do but it is time consuming. You will likely have to do the door window and adjust the vert top at the same time.
Everything needs to be in good shape. The door hinges, the window channel & rollers, the stops, the weather stripping, the channel seals, quarter window vertical seal etc.
Pull the front(optional) and rear seats. Pull the door and rear interior panels. You need good lighting. The top needs to be down, (edit I mean up and locked to the windshield not down stowed away in the trunk).
Then its a matter of sitting in the car and adjusting. Small adjustments and one adjustment at a time.
Mark the original location of all the adjustment points. Good time to lubricate the mechanisms too.
droldsmorland is offline
Old December 22nd, 2023, 01:05 PM
Chapter 6 of the Fisher Body Manual
joe_padavano is online now
August 24th, 2023 02:02 PM
1980olds442
April 18th, 2023 12:48 PM
eric66
November 4th, 2021 11:05 AM
Four Four Tony
April 12th, 2010 08:26 AM
fizzy55
September 30th, 2009 09:18 PM
Quick Reply: Window adj?
