Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
1961 starfire front emblem bar
Old February 2nd, 2018, 08:56 AM
Guillaume's Avatar
Hi , i am interested to install a 1961 starfire front emblem bar on my 1961 f85 so someone knows if that can be fit on my F85 ? the emblem is removable or not ?
Guillaume is offline
Old February 3rd, 2018, 12:18 AM
61Bat's Avatar
It is all one casting. The center is not removable it's painted red.
61Bat is offline
Old February 3rd, 2018, 12:21 AM
Guillaume's Avatar
Thanks 61Bat ! do you know the lenght about this bar please ? if i want to look for one , what the name of this part ?
Old February 3rd, 2018, 12:24 AM
61Bat's Avatar
Its maybe two feet long or so. I guess you would call it a grille bar for a Starfire or a 98. I just bought mine from Ebay not that long ago. There were two of them at the time from different sellers but I haven't seen one lately.
You might want to run a wanted add on here if you want one. Did you say you wanted it for an F85?
61Bat is offline
Old February 3rd, 2018, 12:41 AM
Guillaume's Avatar
yes , for a custom application , i find this bar more cool than the script under the grill and i would like to use another oldsmobile part otherwise , i think to build custom one . i am going to check on ebay , thanks for all these informations !
Old February 3rd, 2018, 07:14 AM
61Bat's Avatar
Let me know i can take some close up pictures if you need some.
I like the idea the grills are so similar. I'd love to build a gasser style 61 F85 in black.
Could you post a picture of your car?
61Bat is offline
Old February 3rd, 2018, 07:37 AM
Guillaume's Avatar
if you can take some pictures with measurements , i will appreciate !
Old February 9th, 2018, 01:30 PM
Guillaume's Avatar
61BAT , don't forget me for more informations about the grille bar please
Old February 9th, 2018, 02:31 PM
61Bat's Avatar
so sorry I will get them up tomorrow! Totally forgot my bad.
61Bat is offline
Old February 10th, 2018, 12:24 AM
Guillaume's Avatar
i would be nice if you can give the lenght , the thickness and a picture showing how the bar is fitted please ?
Old February 11th, 2018, 02:03 AM
Guillaume's Avatar
and if you can give me the lenght between each fitting oint at the back of the bar too
Thanks for your time
Old February 11th, 2018, 07:55 AM
61Bat's Avatar
I hope you can see this shot is between the grill and the radiator with the hood hold down plate removed it shows how the center grill bar is mounted I actually used my two Center Oldsmobile mounts to mount the grill bar but the out side mounts did not line up I will have to modify them slightly.
The bar is 37 in wide roughly by 3 in total depth. Each blade is about an inch and a half wide.
61Bat is offline
Old February 11th, 2018, 10:57 AM
Guillaume's Avatar
Thanks so much ! i think i should make custom one because the globe emblem is at the place where i must put my hand to pull the mechanism to open the hood but , i am going to look for an og grille bar and get one to check if all is ok or not with the hood .
Thanks again for your help and your time
Old February 13th, 2018, 01:11 PM
D. Yaros's Avatar
The 1962 full-size Dynamic 88, and perhaps the Super 88 used a similar bar on the tail panel. I see them on ebay from time-to-time. It might meet your needs?
D. Yaros is offline
mr bojangles
Suspension & Handling
February 10th, 2021 06:03 AM
mjmyaire
December 15th, 2016 10:26 AM
jwedeen
Body work
March 6th, 2016 08:41 PM
1961olds
December 13th, 2013 12:38 PM
1961olds
October 19th, 2013 05:58 PM
Quick Reply: 1961 starfire front emblem bar
