Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Olds Engine Identification Help
Old December 11th, 2022, 06:21 PM
mileggarmy's Avatar
i got and Oldsmobile engine with trans but i cant decipher what type of engine please help.
4790 6M50.01 G on top of engine behind water pump
3F90085?? Cant tell last two, this is on side of block under head please help
1st part number front of block
2nd part of cast on top front of engine looks like there is a g at the end
i
mileggarmy is offline
Old December 11th, 2022, 06:32 PM
66SportCoupe's Avatar
Everything is leading to it being a 307 Olds engine
66SportCoupe is offline
Old December 12th, 2022, 06:00 AM
The "GM5.0L" is all you need to know. Do the math. 5.0 liters is a 307. I can't clearly make out the VIN derivative stamp, but if that's a "3F9xxxxxx" then the "F" indicates the 1985 model year and the "9" would be Oshawa assembly plant. Which heads are on the motor?
joe_padavano is offline
Moegs
October 15th, 2022 08:36 PM
Tgbunch
June 29th, 2022 05:18 PM
ericisback
October 21st, 2021 06:20 AM
adrianirish
May 12th, 2021 09:17 AM
nitrojunkie1029
November 11th, 2013 10:07 AM
Quick Reply: Olds Engine Identification Help
