Other Oldsmobiles Anything not listed above, such as F-85 (1961-1963), Firenza (1982-1988), Starfire (1961-66 and 1975-80), Omega, etc.
Update on 62 Starfire ventilation vacuum control panel
Old January 17th, 2022, 01:59 PM
dennis_30281's Avatar
First of all I can't believe that none of this curious mob has had one of these valves apart before, then again I don't see many Starfire posts anymore.
Back to the valve. I had a spare, so I took it apart and found that it was a metal to metal rotary sliding valve, very simple in operation. I put some bearing grease on the mating surfaces of the valve and put it back together and wall la it works. I hooked it up to the vent door diaphragms and all worked as advertised.
I summarized that the felt on the end of the was to put a drop of oil on periodically to keep the valve working properly.
dennis_30281 is offline
FTolliver
June 7th, 2021 07:36 PM
Rob delta
December 6th, 2011 05:34 AM
rlafash
January 7th, 2011 11:29 AM
70 ctls
May 9th, 2010 10:53 AM
59-59-59
March 31st, 2008 12:48 PM
Quick Reply: Update on 62 Starfire ventilation vacuum control panel
