1965 olds 425 pistons
Old January 11th, 2019, 07:06 AM
doggonn's Avatar
i need a set of 1965 olds pistons . have shopped around and found them with kanter egge mondello please respond if you can supply your your me with knowledge on whats good and whats bad
doggonn is offline
Old January 11th, 2019, 08:43 AM
All of the aftermarket cast pistons are shorter than factory so the compression ratio will be less than expected unless you do some machine work to compensate.
Cutlassefi (Mark) on this site has introduced a forged piston that is the correct height, is lighter, and uses a modern thinner ring pack, all of which result in more power and reliability.
Fun71 is offline
Old January 11th, 2019, 09:10 AM
therobski's Avatar
I sent you a PM
therobski is offline
Old January 11th, 2019, 10:10 AM
BillK's Avatar
Standard bore or oversize ?
BillK is offline
Old February 1st, 2019, 01:27 PM
HolidayCoupe's Avatar
I have numbers 1 2 3 4 7 and 8 pistons and rods available std size.
HolidayCoupe is offline
Old February 4th, 2019, 07:23 PM
65 olds 98 convertible's Avatar
I have a complete motor from a 65 olds 98 if your interested
65 olds 98 convertible is offline
Old February 5th, 2019, 08:10 AM
doggonn's Avatar
Bought a set from cutlassefi 30 over forged great piston from a good reliable source . Thanks mark
doggonn is offline
edzolz
September 28th, 2018 05:29 AM
edzolz
November 2nd, 2015 09:40 AM
classicninja
November 21st, 2014 06:47 AM
Olds92
November 7th, 2011 10:49 PM
Jaybird
December 1st, 2010 06:59 PM
Quick Reply: 1965 olds 425 pistons
