403 vs 403
Old April 4th, 2024, 05:06 PM
cutlassefi's Avatar
403 vs 403
I’ll be doing two 403’s, one with iron heads, one with new Edelbrocks. But some other differences as well. However both will have RPM intakes, and all roller valve trains.
I’ll post both sets of build specs in the coming days.
cutlassefi is offline
Old April 5th, 2024, 10:23 AM
69OldZman's Avatar
Patiently waiting. This should be informative.
Thanks for doing this.
69OldZman is offline
Old April 5th, 2024, 04:11 PM
Mark, when you are really looking for something to do, try a short-stroke 400 vs a long-stroke 400 vs a 403, built as closely the same as possible. By the way, which iron heads?
joe_padavano is offline
Old April 5th, 2024, 04:30 PM
cutlassefi's Avatar
Here are the build specs for each;
Build 1)
#5 mildly ported irons
Hyd roller, 227/234@.050, 108lsa, .576/.573 lift
10:1
RPM intake
QF Hot rod series 750
Build 2)
Out of the box Gen III Edelbrocks
10:1
Hyd roller 233/238@.050, 110lsa, .587 lift.
RPM intake, minor port matching
Holley Terminator TBI
Both will be blowing thru my 1 3/4 dyno headers and 2.500” exhaust.
Should have results in the next 7-10 days.
Old April 5th, 2024, 04:34 PM
Rocket Renegade!
I didn't know Mark takes requests () but I would love to see this too.
BangScreech4-4-2 is online now
Old April 5th, 2024, 07:01 PM
deadeyejedi's Avatar
Subscribing
deadeyejedi is offline
Old April 6th, 2024, 04:52 AM
cutlassefi's Avatar
That would be an interesting comparison for sure.
But I don’t see it happening, mainly because I’d have to use flat tappet cams in all three to keep it legit. Can’t do a roller for the .921 block. Like a lot of others, I’m not doing flat tappet builds anymore. Sorry.
Old April 6th, 2024, 06:59 AM
Bernhard's Avatar
The difference in power levels would be interesting. In my opinion what engine placed first second and third would not be a surprise just the max HP/TQ and power curve.
1. 403
2, 400 E
3. 400 G
Bernhard is offline
Old April 6th, 2024, 08:35 AM
1. 403
2, 400 E
3. 400 G
I would agree with that ranking, assuming all three used the same heads. There will be a difference in the intake, naturally.
Old April 6th, 2024, 08:38 AM
cutlassefi's Avatar
And the same compression(I’d use bb heads on all three, which would necessitate a piston change on the 403) cam, and carb size. Lots of potential costs and variables here guys.
I can get solid roller lifters for a .921 block but they’re very pricey, about $1500.00. Not sure I want to bite that bullet either unless someone wants to buy that build. Just sayin.
Old April 6th, 2024, 02:30 PM
Duh
Duh's Avatar
Just use 842 lifter blocks. Yes they will be 45°.
Duh is offline
Old April 6th, 2024, 03:14 PM
cutlassefi's Avatar
You have one you want to donate?😉
Old April 6th, 2024, 05:02 PM
Duh
Duh's Avatar
If you want to pay for shipping from NJ I just might have one in my garage. It does need some work.
Duh is offline
Old April 6th, 2024, 05:15 PM
cutlassefi's Avatar
Well ok then. Once I get thru the dozen or so I have in the works now, I may take you up on that.
Thanks!
Old April 6th, 2024, 06:46 PM
Pffft, do a windowed 403 vs. a SMW 403.
Sorry, been holding back for days and I just couldn’t help myself.
Fun71 is offline
Old April 6th, 2024, 07:11 PM
Bernhard's Avatar
The amount of over bore on the 403 might also be a variable?
Bernhard is offline
Old April 7th, 2024, 05:17 AM
cutlassefi's Avatar
Of course, everything is.
But I believe Joe’s point is to see how those differences affect power and tq, with the rest of the parts being essentially the same.
Old April 9th, 2024, 03:31 PM
jmcghee's Avatar
Tried Google but cant find an answer . Are the GenIII heads just big block heads?
jmcghee is offline
Old April 9th, 2024, 04:03 PM
cutlassefi's Avatar
They’re the newest ones.
Old April 9th, 2024, 04:15 PM
jmcghee's Avatar
Ge III Heads
So best I can tell these are big block heads you installed on this engine.
jmcghee is offline
Old April 9th, 2024, 04:52 PM
Using big block heads on a 403 cubic inch engine makes sense.
Fun71 is offline
Old April 10th, 2024, 06:01 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
Yeah, they are the 77cc large valve version. You can bolt them on a small block but you need a 4.125" bore minimum to clear the valves.
olds 307 and 403 is offline
Old April 10th, 2024, 03:22 PM
OK65Cutlass
OK65Cutlass's Avatar
Hey Mark, how do the intake/exhaust ports compare on those heads?
OK65Cutlass is offline
Old April 10th, 2024, 04:10 PM
cutlassefi's Avatar
Hmm not exactly true. The chamber is only about 4.100 wide to begin with.
They didn’t change the valve centers vs any of the earlier designs.
Old April 10th, 2024, 06:40 PM
Good to know. What would you recommend as a minimum bore size?
Old April 11th, 2024, 04:40 AM
cutlassefi's Avatar
Just that, 4.100. The small block version should be right around 4.00, mine are.
Old April 11th, 2024, 05:20 AM
cutlassefi's Avatar
The irons would be significantly smaller than the Edelbrocks. And the Edelbrocks are larger than a regular big block head as well.
allyolds68
April 8th, 2016 10:37 AM
88hurstolds
February 22nd, 2016 02:53 PM
rktolds
October 20th, 2014 06:38 AM
330oldsmobile
January 2nd, 2011 05:45 PM
J-(Chicago)
April 9th, 2008 04:28 AM
Quick Reply: 403 vs 403
