Home Porting Techniques
Old October 14th, 2019, 12:07 PM
  #1041
Kyle's77cutlass's Avatar
Great build and hopefully you son has good friends and sense. That car will get him into trouble in a hurry, if he wants it🙂. I have set of filled #6 heads, 2"/1.625" valves and some port work. The exhaust ports look nice, I think the intake can use some work, won't know how much was done till I pull the valves. The guy I bought them from with 9.6 to 1 a .060" over 350 with a Comp 280H in a super heavy 74 Delta 88 ran 12.7's, can't be junk with those times and weight. Pics in the next couple of weeks.
Yes thanks, he will enjoy the ride. Still a bit away tho, was hoping this late summer he would of been using but build took too long. Now with number way over and beyond, need a built trans and rear end to take the additional power. Will send it to my freinds shop and will work over the winter on it. And have to run new exhaust cause ofvthe headers.
But with this all said and guys are calling #8's junk cause of smog heads. The tests came back, and that is a lie. If you dont port them then yes they are. But if you are porting a set of cast heads, way better off to go with #8"s. And there is a chart to show the flow numbers. Yes I put alot work into them but to me well worth it. Complete port and polish, risers filled 2 inch valves and seats, rocker studs. Yes you can buy aluminum heads and may do better, they still need to be played with. To me its not the same love for an Olds motor
Kyle's77cutlass is offline
Old October 14th, 2019, 12:20 PM
  #1042
The left is #8's and right is #7a's. A big difference in the bowl area. The #8's seem to aid to aim direction into the engine.
Old October 14th, 2019, 12:22 PM
  #1043
The only thing I was not able to the heads was polish the exhaust ports. The machine shop cleaned them up for me
Old October 14th, 2019, 08:12 PM
  #1044
wr1970's Avatar
Mid Am what a joke.😂
wr1970 is offline
Old October 15th, 2019, 06:17 AM
  #1045
VORTECPRO's Avatar
Keep up the good work!
VORTECPRO is offline
Old February 28th, 2020, 04:50 PM
  #1046
oddball's Avatar
I just did my first adventure in really trying to port heads. I've removed exhaust bumps, cleaned up flashing, unshrouded valves, gasket matched, etc before, but never more than that.
Took some fresh 60519's, unshrouded the valves to a 4.27" gasket, raised the exhaust bowl roof a ton (almost level with the port), tear dropped the intake guide boss (although current castings have a very small boss to begin with....), tried to lay back the short turn, blended anything real ugly. Quicky "polish" with 80 grit rolls on the walls. That's it. The bowls in these castings are pretty well blended to the seat already so not much to do there. Stock valves, no valve job yet, didn't cut down the exhaust guide.
My machinist has a Superflow 600 but hates running it. So he let me play around with it for an afternoon. My main concern was making sure I didn't ruin the head since, really, I have no idea what I'm doing.
Test configuration: 28" water, 4.155" bore, head clamped to machine with 4.27" cometic gasket. Putty around intake port, nothing on the exhaust port. No measurable leakage.
"60519 unshroud" is an out-of-the-box 60519 with just the chambers opened up to 4.27". "60519 JO" is the one I did all the porting to.
"60519 stock" is CutlassEFI's numbers, so of course can't guarantee direct comparison. Interesting the 0.100" numbers on mine are so much lower.
Given all that porting took somewhere around 4 hours, was it worth it? I guess so on the exhaust, but looks like the current ebrock intake is as good as it's going to get without serious work (moving pushrods, sleeving bolt holes, bigger valve, someone knowing what they're doing, etc). It was interesting on the bench - the unported exhaust port just sounded awful. Tons of turbulence. The ported one still sounded like crap, but much less crappy. The current ebrock casting also has a pretty funny ski jump ledge on the exhaust port exit.
At least I didn't ruin the head, and didn't poke any unwanted holes in it.
Now to figure out how to reliably install and size guides...........
oddball is offline
Old February 28th, 2020, 05:43 PM
  #1047
VORTECPRO's Avatar
Very sensible approach. You will be surprised how well production parts can work.......if you know what to do, and it seems you do.
Old February 28th, 2020, 06:38 PM
  #1048
cutlassefi's Avatar
Nice job Jason. Don’t worry about the @.100 numbers, piston isn’t really doing much at that point anyway.
cutlassefi is offline
Old February 28th, 2020, 07:56 PM
  #1049
VinMichael's Avatar
Is production referring to factory heads, or Edelbrock/Procomp. Oddball seems to be working on Eddy’s
VinMichael is offline
Old February 29th, 2020, 06:55 AM
  #1050
oddball's Avatar
Thanks, Mark. Wasn't sure if maybe the 0.1 numbers are indicating a difference in the test bench, difference in the head, or difference in the operator. There's a reason the Superflow template flow sheets have a spot to write down who operated the bench.
Regardless, at least my work showed gains and not losses.
He had a LS head sitting around that he flowed a couple of years ago. I used that as a benchmark and got the same numbers he got, so seems I'm running the bench the same way he was. Well, the same way whoever the dude was that he used to call in to run the bench.
oddball is offline
Old December 24th, 2020, 02:41 PM
  #1051
Chevy budget Olds powered
coppercutlass's Avatar
Man. What a trip this thread is. Those heads that kinda kicked off this thread which 67cutlassfreak did have worked great for me. With my 72 cutlass running a best of 11.68 @ 111 mph. With the little 350 . In the coming months I plan on porting my own heads for a little SBO project I plan. Probably one of the best threads on this website.
coppercutlass is offline
Old December 24th, 2020, 06:09 PM
  #1052
Yeah this thread is awesome. Lots to read and lots to learn.
I enjoyed porting the heads for Kelvins build.
Old February 7th, 2021, 02:09 PM
  #1053
Vanguard's Avatar
During the covid shut down I decided to finish the 455 build I started years ago. 69 455 with C heads.
Had a diesel repair shop weld the center exhaust divider and a friend milled the exhaust gasket surface flush.
Sweet talked a buddy at a foundry and filled the cross overs.
I then polished the chambers, removed the 'egr' bump, smoothed out the bowls and guides. Also cc'd the chambers with within .2 cc. 82 cc final Lots of time invested ! ! Practiced on a set of Ga heads and broke thru
Ended up with 9.5:1 compression. dual spring yields 130 seat 340 open. Used a 230/236 flat tappet with an 850 double pumper, ported Edelbrock torker and headers. Engine runs great !! incredible power . . everywhere in rpm range ! Although I tend to avoid it, motor revs to 6,000 easily
Here are some pictures before the machine shop cut a 3 angle valve job, installed new guides, cut the valve spring seats to obtain proper installed height, and lightly milled the heads.
heat riser filled with aluminum a356
center divider welded and milled
port before valve job and new guides
chamber before guide work and valve job
Vanguard is offline
Old February 7th, 2021, 03:29 PM
  #1054
wr1970's Avatar
Yes I love all the info on this thread.
wr1970 is offline
Old February 7th, 2021, 03:33 PM
  #1055
Bernhard's Avatar
x2
I know cast iron heads are not practical but I enjoy seeing cars running hard with the old iron heads.
Bernhard is offline
Old February 7th, 2021, 03:35 PM
  #1056
Bernhard's Avatar
Nice
Bernhard is offline
Old February 10th, 2021, 10:34 AM
  #1057
maxi426's Avatar
I'm working on a pair of 1972 7a heads, and have a question about the short side radius. The intake valve size has been increased to 2.07. If I open the throat appropriately for the new valve size, and lay back the short side to the radius of the throat, it looks like I'll have to remove approx. .080-.090 of material at the short side apex. Is there enough material at the apex to do that, or should I take less to be safe?
maxi426 is offline
Old February 10th, 2021, 10:41 AM
  #1058
I would be careful on the short side.
Old February 10th, 2021, 05:36 PM
  #1059
VORTECPRO's Avatar
Get a junk 7A head and cut it apart, you could also sonic CK. When your porting listen to the port, you can hear when its getting thin as well.
Old February 24th, 2021, 09:47 AM
  #1060
GMC Shorty's Avatar
WOW!
I know when drilling you can "hear" when you're almost through, but not sure I'm risking all that work on the head
GMC Shorty is offline
67 Cutlass Freak
March 24th, 2016 08:42 PM
nukesec1
November 30th, 2013 09:02 PM
DoubleV
June 20th, 2013 06:51 PM
68Tom
April 3rd, 2009 05:33 AM
Quick Reply: Home Porting Techniques
