Cant figure out why 307 wont start
I just bought a pontiac firebird with a 307. I put a holley carb on and it would start and run. I had it running and it started spitting gas out the carb and caught fire and i had to dump a bunch of water to put it out. Only damaged some wiring and the distributor cap, so i replaced the wires, cap and coil and ran a positive wire to the cap for spark. It has spark on all cylinders, seems to have good compression and i cant get it to start with starting fluid. Any ideas?
If you literally dumped water down the carburetor - that water is still inside the intake manifold and most likely every single cylinder. You need to remove every spark plug, clean & dry every spark plug (or install new spark plugs) & clean/dry out the intake manifold & every cylinder probably with compressed air and allowing it to air dry for several days.
No it was not running and I already took the plugs out and extracted the water I just forgot to mention it in the post. With starting fluid it shoots some fire from the exhaust manifold but doesn't seem to try to actually start.
Still do a compression test if you can get a gauge.
Since the wires were replaced, confirm #1 is at TDC on the compression stroke, lift the distributor cap to confirm #1 plug wire aligns with ignition rotor, reinstall distributor cap and double check the firing order. Remember Olds distributors turn CCW.
I felt it with my finger it felt strong, however i set the motor around 20 btdc according to the tab on thw front, and the distributor was pointing to cylinder 8. Nothing mechanical was changed so this doesn't make sense to me
Since it is a 307 I @$$ume it's an HEI distributor. Did you remove the ignition module from the distributor for cleaning? Since you used water to extinguish the engine fire you should reapply heat sink paste to the bottom of the ignition module.
What year Firebird? The early to mid eighties ran a 305 which is Chevy. All above would be correct and the firing order would be different and the distributor would turn clockwise. Can you post a picture of the engine bay?
pat
pat
Pat, That's a good question!
@ thegrantler...where does oil get put in this engine, through the valve cover or through a vertical tube at the front of the engine? Depending upon the year I'm wondering if this could be a SBC, Pontiac or an Olds transplant motor.
A picture of the engine would be best.
Its an olds transplant, not factory. I tried moving the distributor to align properly but didn't help. Also tried moving the plugs. I was thinking the timing was off but I just don't see how that could have happened from a fire or water being in there. All the stuff in the distributor didn't get wet and none of it got bunt, just the cap and wires. I've double checked the wire locations too
This means there is something wrong with your ignition timing. It could be anything from being wired wrong to distributor position.
Backfiring out of the intake, it may be 180 degrees out meaning the TDC when the distributor was installed was on the exhaust stroke it needs to be TDC on the compression stroke. At TDC compression the rocker arms on cylinder #1 are both closed and won't move if the crank is turned a little in either direction, the rocker arms on cylinder #6 are both closed at TDC but both will move very soon as you move the crank back and forth.
Put a compression gauge in cylinder #1 and confirm that it is at TDC compression. If you don't have a compression gauge you can either feel for the compression or put a tissue in the spark plug hole lightly and the compression will blow it out.
I've done this also. It's pretty handy if you are by yourself and bumping the starter with the key. You can usually see the paper blow out from the driver's seat.
#31
Im pretty sure its an hei, the coil sits on top of the cap. All of the water was thoroughly flushed out along with new plugs. Nothing mechanical was changed so I don't know how the timing could be off. And the rotor only goes on one way along with the cap
#32
If you can't be sure what type distributor you have and you're guessing e.g. "...pretty sure it's an HEI..." you need to CONFIRM what type it is. Guessing buys you nothing. You're not making this easy. As has been suggested, post a picture of your engine bay and in particular your distributor.
If you don't know how to post a picture, read this >>> How To Post Pictures/Images
#33
#34
#38
Youre wire order on the cap is not correct
And did you replace the coil ground when you installed the new cap. I see a coil ground laying next to the old coil on the cowl
Is that distributor from a CCC car, I dont see a vacuum advance canister
Do yourself a favor and cover the carb opening with tape, or something, to prevent any crap from falling into the intake
