1961 (and later?) Dynamic 88 Eibach Springs--FOUND
Hi guys--thought I'd pass this on.
I have a '61 Super 88---but this info should be good up to '63, maybe '64 full size?
Anyhow trying to source out some lower springs. Eibach didn't list the '61.
Checked out the '61 spring specs and long story short they were the same as '91-'96 Caprice/Impala---front and rear.
So I ordered the Eibach set for an Impala SS, PN 3837.140. BTW there is another set from Eibach (PN 3832.140) for the standard Caprice which is won't drop the car as much.
Fronts went good. Lot easier to install than stock because they are shorter. I did add a half inch rubber spacer to the base of each spring. Front end needed to come up just a tad. I'm running pretty tall tires all around (255/70-15) so touching the fender when turning was a concern. I carefully bent up the edge of the fender lip and also made some limits for the steering stops. Works real good!
And for the rear I simply installed them.
Before install ground to frame measurement was 9-1/8". After installation it now measures 7" front and 7-1/8" rear. Handles and rides nice. The rear is less ride height sensitive now---i.e. difference between full or empty tank.
Overall I'm pretty happy. Sits nice. Would really be low with some 235/70-15's or lower yet with 14's.
What she looks like now:
Steering stop:
Steering stop:
Hey thanks for the heads-up on this. Wasn't having much luck finding any lowered springs for my 62 Starfire until i came across this. However, looking at the Olds parts catalog is see the 61 Dynamic has a different part number for the springs to the 62 88, S88, 98 and Starfire. Can you give a bit more info on where or how you measured the spring specs of your originals? Or is it just height and diameter that matter?
Also are the lowered Impala springs stiffer than the Olds originals, and is the ride/handling better or similar now they in?
You can order springs made for your car from places like this that I used www.jamcosuspension.com They have all the specs for almost every north american car and can build lowering springs 1", 2", or 3" drop I think depending what you want. I think the set I bought for my 63 was about $300+ shipping. They have a 20% stiffer spring rate I think I recall them telling me.
Since my post and pictures on this I have went down to a 235 front tire. I pulled the steering stops off and now can turn sharp without any rubbing. Keep in mind that I kept the ~ 1/2" rubber spacers on the bottom of the front springs.
Yeah you know the ride with the stock springs was sort of stiff---and it's pretty much the same with the Eibachs. Handles better though.
I'm very happy with the install. And Summit had them in stock ready to ship.
I found the easiest way to find comparable springs was to go to the www.Rockauto.com website. They will list the springs for your specific car. Then you can click on the part number and see what other makes & models use that same part number. You can then lookup aftermarket lowering springs for those cars.
Thanks for posting this. I need to do the springs on my 61 as well but I don't really have a reference point of how the original springs should look or handle seeing as they've been bad since I got the car. The bottom rear edge of my front inner guard is just 6.5" from the ground. It's made worse by the new crossmember that holds up the 55 hydramatic I've got hooked up. That brings current clearance down to just 4". The Eibach springs sound (and look) great but that might work so well with my clearances. I see the Eibach kit is supposed to lower the Impala front by about 1.2". If you found it lowered yours by 2" (even with a spacer) can I assume that fitting regular 94-96 Impala springs would lower an Olds by 0.8"?
I see the Moog part for the 96 Impala is 5044 Inside Diameter 4.080 End Type 1 Square End Type 2 Tangential Bar Diameter 0.687 Install Height 11.00 Load in Pounds 2360.0 Spring Rate 334.0 Free Height 18.06. and the rear Moog part CC621 Inside Diameter 5.530 End Type 1 Pigtail End Type 2 Pigtail Bar Diameter 0.672 Install Height 12.75 Load in Pounds 640.0 Spring Rate 175.0 Free Height 16.70
Are these the figures you were working on with your comparisons? Could you post the spring details for our Olds and also of the Eibachs for comparison?
I'm thinking standard 96 Impala ss springs might be an alternative for me. From the quick reading I've done the Impala springs were reinforced compared to the Caprice. Given that the Olds are 250lb lighter I'm not sure the implication - maybe a slightly higher ride height to the Impala?
Do you have any pics of your vehicle on standard springs before you fitted the Eibachs?
Phillip
'61 Dynamic 88 BBL Top
Phillip
Hi Phillip,
Can't find my notes from back when I was doing this but I was comparing stock Caprice springs to the '61 springs and things were almost identical. And I never recorded any specs on the Eibachs.
If it does help I did come up with two pictures of my car before the spring install. These pics have the car sitting on 255's all around just like the pictures in my first post. Pretty easy to see how far the car came down.
Phillip
Thanks - according to the '61 Owner's Manual the load height for the rear springs is only 5 13/16" to 6 9/16". This seems extremely low. But then someone else suggested the load height is 9". Does any of that sound familiar to you - I'd really like to find out what it's supposed to be. Can you remember where you got your original information?
Anyhow to summarize----when running the Eibach PN 3837.140 spring set (with a 1/2 rubber spacer under the front springs) in my '61, I measured 7" front and 7-1/8" rear from the ground up to the rocker panel. And this while running a 28.9" diameter tire. Your 205/75-14 is probably a 26" tire so you would be looking at about 5.5 inches to the rocker panel. Might be too low for you. Hard to say with any certainty where where the standard SS Impala springs would put you----but your logic looks right on.
For the spring comparison I was dealing out of a TRW chassis book. And for my height measurements I was going off of the front and rear of the rocker panel. Not sure where the '61 shop manual is measuring.
Hi again. MYOLDs is a good mate here so we're kinda sussing this spring thing out for both our cars... you mention adding that rubber spacer to the front to bring it up "a tad". was that just personal preference for the look or was it to avoid rubbing somewhere? I'm about to order the same impala springs from JEGS but would like the front a little bit lower than yours ... personal preference and i think would look better with the 20" rims i've got coming. so the springs sound ideal if the spacer is not necessary.
Those 20's sound pretty good. Keep us posted!
Just remembered this---however it's more a product of the wide tires and rim offset. I had to put a spring on each emergency brake cable to pull it away from rubbing on the tire. Basically spread a big cotter pin in one of the holes in the lower control arm to act as an anchor for the spring.
Thanks, yea good point. I had initially order 255s for the rear with the new rims but it seemed I might have only 5mm clearance either side which got me nervous, especially if my backspace measurement is slightly out. So i reluctantly went down to 245s. Have ordered the same springs so will post a follow up pick when they arrive, including the wheels.
hiya... well, the new wheels and tires arrived recently along with a set of the Eibach Impala springs. So heres a few shots of the Starfire pre-installation of the new springs. the rear looks quite good as is, but the front definitely could do with lowering a couple of inches. Will hopefully get around to installing the springs sometime soon and will then repost some pics for comparison.
Well.... been 6 months but finally got some photos to upload of the Starfire lowered with the eibach impala springs. only front springs swapped so far as I think it looks quite good as is. I too had to put rubber spacers in to bring the front up to avoid guard rub. 9/16" thick on the passenger side but had to install 1" on the drivers side which i thought was strange until i saw in the parts manual that the original springs were two different part numbers for non AC cars. stood my originals up next to each other and what do ya know? they're different lengths. anyway, it drives great now. much less body roll than previously although I also replaced the sway bar bushes at the same time so its all mint now.
Yeah I noticed the difference in my original front springs too. When I first got my '61 it was lower on one side. Kept playing with spacers and spreaders to level it out-----then the Eibachs took care of it.
Anyhow glad things worked out for you.
Little update here.
I was running 235-70/15's front and 255-70/15's rear. The 235 is 28" tall and the 255 is 29.1".
This looked pretty good and gave a little rake with the Eibach's. However the 255 rears had so much more sidewall than the fronts.
So today I put on some 275-60/15's on the rear. They are a 28" tall tire just like the front. I think it really looks better. And it brought the rear down another half inch basically leveling it out.
These 275's are a tight fit but they work. Probably just about as big as one can go on a '61. BTW the rims are 7"-----1990's Caprice.
Anyhow here's a shot:
426Hemi,
hey quick query, thinking of putting my rear Eibach springs in now from the same kit you used (#3837.140). Did you find the OD of the Eibach pig tail ends (4") are wider than the original springs? And if so did you need to make up new clamping plates to fit them? reading your post from the top again it seems you didn't but thought I should ask. I'm concerned I might run into problems with mine.
426Hemi,
Good luck on the install and shoot us some pics when finished.
Gabriel still lists front shocks for '61 Olds. #82079.
I'm told their # 82060 will work for the rear, though they are actually listed for Cadillacs.
Both of these are modern gas charged shocks in Gabriel's "Classic" line.
#31
I bought the Gabriel 82079's at AutoZone for the front---$19.99. Didn't do the rears yet---thanks for the head's up on the Caddy rears. I see AutoZone has those too.
#32
Little update here.
Question on the tire fitment. I am in the middle of putting on the impala ss springs. I'm wanting to go with either a 17 or 18 inch custom wheel. I assume you would suggest no wider than 7 inches, but what tire size do you think would fit? 275/?.... This is all on my 61 dynamic 88 ragtop.
W
#33
W
W
My front tire is 28" tall, 9.5" section width and 7" tread width. About the max as far as the fender lip and turning radius is concerned.
The rear tire is 28" tall, 11" section width and 8.9" tread width. About the max for the wheel well and control arm/emergency brake cable.
It might be worth keeping these measurements in mind when choosing your 17" or 18" tires.
My 7" wide rims worked good------with about neutral backspacing. Anything wider would have spread the section width.
Maybe some others who are running the larger diameter wheels will have some input too.
Joe From NY
April 14th, 2010 07:41 PM
