steering shaft doesn´t aling--- 65/ 455-442
Old February 24th, 2024, 02:22 AM
STLCRZY's Avatar
Hi
I notice that my complete steering shaft doesn´t aling ( 65/442-455). I really have problems to put the lower steering bearing in the column.
The shaft is 100% straight.
Because i cant´ change the bolting position of the Steering box to the frame and the column under the DASH with the 2 Bolts it seems the like frame horns not straight or the cockpit on the frame sits not straight...ist his correct ?
STLCRZY is online now
Old February 24th, 2024, 05:49 AM
Are you saying that the shaft is laterally misaligned from the box? If so, have you unbolted the panel that holds the lower end of the column at the toe pan? Note the oversize holes that allow for adjustment.
joe_padavano is offline
Old February 24th, 2024, 10:02 AM
STLCRZY's Avatar
Joe unbolted this plate,but it doesn´t help.
Old February 24th, 2024, 10:05 AM
Didn't it align when you took it out? Obviously something is assembled incorrectly. Start by completely unbolting the column from the dash and toe pan, connect the rag joint, then reattach the column. When the column is unbolted from the dash and toe pan there's nothing holding it in any orientation.
Old February 24th, 2024, 10:16 AM
STLCRZY's Avatar
I have tested this several times , it seems that it doesn´t align beetween the bolting points ( Box and column /2Bolds under the dash )
Old February 24th, 2024, 11:35 AM
STLCRZY's Avatar
To correct this miss aligment, do i need a single or double u-joint?
Old February 24th, 2024, 11:40 AM
Loaded68W34's Avatar
First you need to post some actual photos (at the steering box, at the firewall, under the dash) of the mis-alignment you are talking about.
Loaded68W34 is offline
Old February 24th, 2024, 11:51 AM
STLCRZY's Avatar
Will do
Old February 24th, 2024, 11:55 AM
Is this an aftermarket column?
Old February 24th, 2024, 11:56 AM
STLCRZY's Avatar
No Joe
Old February 24th, 2024, 12:41 PM
2blu442's Avatar
Yes, pictures would help. The early Toronado's had a u-joint in the column. But the Cutlass/442 shouldn't have unless we're mixing up the terms, u-joint vs rag joint.
2blu442 is offline
Old February 26th, 2024, 05:27 AM
STLCRZY's Avatar
Hope it helps
Old February 26th, 2024, 11:31 AM
STLCRZY's Avatar
Would a single u-joint like the sweet 401-50606 help to correct this misalignment if install direct before the lower bearing ?
https://sweetmanufacturing.com/product/401-50606/
Old February 26th, 2024, 11:44 AM
Stop.
There was no U-joint needed from the factory. If the car has the OEM steering box and OEM steering column, then figure out why they don't align. If you unbolt the toeboard plate, there are inches of lateral adjustment available. Mate the column to the box FIRST, then bolt it to the dash and toeboard.
Old February 26th, 2024, 11:57 AM
STLCRZY's Avatar
OEM steering column yes
Quick ratio box
Old February 26th, 2024, 12:00 PM
Quick ratio box
It's still a Saginaw 800 box like the original, right? Or is this one of the new smaller 600 series?
Old February 26th, 2024, 12:32 PM
STLCRZY's Avatar
Its a Lares 972 or 974...believe must be a800?
Old February 26th, 2024, 12:36 PM
So back to my original point. The column and box were aligned when the car left the factory. Presumably they were aligned when you took it apart. What is different now?
Old March 16th, 2024, 02:23 AM
STLCRZY's Avatar
...if anyone have the same situation YES the sweet 401-50606 correct it
Old March 17th, 2024, 07:30 PM
nsnarsk65cutlass's Avatar
Hard to say for sure from the picture, but maybe a lower column bearing issue.
nsnarsk65cutlass is offline
Cald1973
October 13th, 2022 03:59 PM
skekas33
December 1st, 2020 02:26 PM
STLCRZY
July 4th, 2019 03:57 AM
bobmobile
April 18th, 2015 08:51 AM
Stevec
Suspension & Handling
August 4th, 2011 08:36 AM
Quick Reply: steering shaft doesn´t aling--- 65/ 455-442
