Tech Editor's Desk Projects, papers, writings, thoughts, musings of our technical editor Joe Padavano. To begin with, he will be making threads and can approve posts to it if he wishes. This can be changed in the future if it does not work out well.
Electric choke wiring
Old May 21st, 2018, 03:51 PM
  #81
The green and blue wire described are correct for the idiot lights.
oldcutlass is online now
Old May 21st, 2018, 05:06 PM
  #82
'72 Supreme vert (Mango)
adis's Avatar
thx, Eric. Yes idiot lights, not gauges.
adis is offline
Old May 21st, 2018, 05:48 PM
  #83
cfair's Avatar
See Joe P's diagram for an oil-pressure-linked choke.
It's a good move: No oil pressure, no power to the choke = good safety precaution. You need a different sensor and you'll need to cobble up a connector using a headlamp plastic terminal. You can get electrical parts to build it from Auveco. Great catalog.
In '66 big cars, the blue/white stripe wire was for oil pressure. The Temp sensor had two green wires (light & dark) going to hot & cold lights. I can't be too sure of the temp sensor wire colors since I'm a bit color blind.
cfair is offline
Old May 24th, 2018, 11:18 AM
  #84
Macadoo's Avatar
Boy, it's been a while but I think you are correct. My green wire still hangs free but I'm using a temp gauge, now. Blue for oil pressure, red is power in (fused) and the third wire is out to the choke, IIRC.
Macadoo is offline
Old September 30th, 2018, 10:33 AM
  #85
Bobbity's Avatar
Before I try this, the PS 127 is good to go on a '64 330? Everywhere I look, it says incompatible, but I'm thinking that's because of the multiple prongs, not the threads...
Bobbity is offline
Old September 30th, 2018, 10:56 AM
  #86
"Everywhere" you look will tell you what the stock replacement part is. This is NOT a stock replacement part for a 1964 Olds, thus it will not be shown as "compatible". No 1964 Olds has an electric choke, so searching "compatibility" is worthless. Every single 1964-1990 Olds V8 has the same 1/8 NPT thread port for the oil sender.
joe_padavano is offline
Old September 30th, 2018, 11:01 AM
  #87
Bobbity's Avatar
Thanks, Joe, that's what I thought. I've never made a mistake before, but, I suppose it could happen. Just wanted to be 99.785342% sure...
Bobbity is offline
Old May 17th, 2019, 08:05 PM
  #88
O'smobile
Orlando 1's Avatar
You may have seen this but I found nice new factory style connectors of various types here:
https://theelectricaldepot.com/weath...ef69e1b212cbd2
P.S.: I know this thread is 10 years old. My car is 50 years old, I think the information will still be good.
Orlando 1 is offline
Old September 18th, 2019, 11:36 AM
  #89
MrEarl's Avatar
Thanks for the Electrical Depot reference @Orlando 1 . I had to temporarily re-route my AC blower fan wiring around a burned out connector and had to just use single plug type connectors. Will be ordering the 3 way male and females and redoing it correctly now.
And thanks @joe_padavano for sharing your trick with the 3 prong sender. I'll be using it.
MrEarl is offline
Old November 21st, 2019, 07:38 AM
  #90
Phoenix8990's Avatar
Electric choke
I decided to wire up the choke on my 69 Cutlass as shown with the inline fuse. I picked up a headlight socket. One side to the alternator, the other to the choke and the middle to the dash light. The light stays on while the ignition is not on. When I turn the ignition on it goes out. I double checked the wiring and it is as shown. Any thoughts?
Steve
Phoenix8990 is offline
Old November 21st, 2019, 07:43 AM
  #91
You have the PS127 switch, right? With the engine not running, there should be continuity from the center terminal to the case of the switch with the engine off and no continuity from the center terminal to either of the other terminals. Check this. The two outer terminals should have no continuity to anything with the engine off and only continuity to each other with the engine on.
Old November 21st, 2019, 11:49 AM
  #92
Electric Choke
Well I'm beginning to wish I had the PS 127, I bought the NAPA OP6610 which is suppose to be the same. I wonder. At any rate I removed the connector and have no continuity between any terminal and the base. I have continuity between the center terminal and one side term. Do I have a bad switch or just one that is not compatible.
thanks,
Steve
Old November 21st, 2019, 11:52 AM
  #93
thanks,
Steve
That's the wrong switch, unfortunately. In fairness to NAPA, there has been some gyration in the part numbers of these switches. The one you have is a common electric fuel pump switch that is not functionally the same as the PS127.
Old November 21st, 2019, 11:53 AM
  #94
By the way, the NAPA switch equivalent to PS127 is OP6618. That info is in the first post in this thread.
Old November 21st, 2019, 12:35 PM
  #95
Thanks, I guess somewhere in the long thread someone put the OP6610 # in and I took the bait. I'll pick one up and post how it goes.
thanks again for your time and help,
Steve
Old April 5th, 2023, 02:28 PM
  #96
Mark21's Avatar
Joe, Sorry to bring this up again, but I have a question about the electric choke setup off the alternator. I've done this and it seems to work fine except the choke wire and housing gets extremely hot extremely fast. I've checked the voltages and wiring per the schematic and it's wired correctly. The problem is that the choke opens up almost immediately. I thought of adding a resistor with a large heatsink to see if I could bleed off the amps. I've swapped the choke mechanism and swapped the oil pressure switch. Just don't know what's going on. Any advice would help. Thanks
Mark21 is offline
Old April 5th, 2023, 07:17 PM
  #97
The electric choke element is designed to be connected directly to +12 V (actually 13.8 V or so in reality). The only way for it to get too hot is if the coil is somehow defective or if your regulator is not working properly. Have you checked voltage at the terminal on the choke coil? Also, have you adjusted the coil to slow the choke opening? You can loosen the screws and rotate the choke coil housing in the carb to change the tension on the linkage.
Old April 6th, 2023, 11:14 AM
  #98
Mark21's Avatar
I'll check it again but I believe the voltage output from the alternator and into the choke is right at 12V.
Update: I verified the voltages. 14.59V while the engine is running. Checked across the battery terminals, at the alternator and at the choke connector. Hmmmm.
Mark21 is offline
1968_Post
July 21st, 2020 05:38 PM
Al Sanchez
March 5th, 2013 04:49 PM
bobfo1
November 25th, 2012 10:37 PM
76Supreme350
May 16th, 2011 05:41 PM
Olds64
July 30th, 2009 10:28 AM
Quick Reply: Electric choke wiring
