Bellhousing bolts?
Old April 11th, 2011, 05:49 AM
defiant1's Avatar
Question Bellhousing bolts?
I cannot find the damn bellhousing bolts from when I removed the motor. Anyone know what size and length these bad boys are? (TH350/350 motor)
d1
defiant1 is offline
Old April 11th, 2011, 05:58 AM
TripDeuces's Avatar
3/8 x 18 x 1.5?
TripDeuces is offline
Old April 11th, 2011, 06:08 AM
defiant1's Avatar
Originally Posted by TripDeuces
3/8 x 18 x 1.5?
3/8 x 16, correct? is there a 18 thread pitch? 1.5" sounds right.
defiant1 is offline
Old April 11th, 2011, 06:10 AM
TripDeuces's Avatar
Yeah 16 not 18, You can just measure the flange thicknesses and add the two together for the length. Just make sure they engage fully
Old April 11th, 2011, 06:29 AM
Registered
Bluevista's Avatar
Oldsmobile parts catalog - 3/8"-16 x 1-3/8".
Bluevista is offline
Old April 11th, 2011, 06:32 AM
defiant1's Avatar
Thanks gentlemen. Off to the parts store I go.
defiant1 is offline
Old November 13th, 2023, 11:58 AM
wozny442's Avatar
Different lengths, what goes where?
Sorry, I know this is an old thread but I thought I’d try. Putting my TH350 back in and noticed that two of the original bolts are a little longer, wondering what positions the longer ones reside in.
wozny442 is offline
Old November 14th, 2023, 06:00 AM
oddball's Avatar
I think only one hole is a blind hole - the others are open on the backside, so it doesn't actually matter.
Having a specific length is more about being able to get a socket/wrench onto the bolt!
oddball is offline
Old November 14th, 2023, 06:33 AM
Sugar Bear's Avatar
Check the depth of a blind hole before putting a bolt in, the bolt should not bottom out in the hole. A bottomed out bolt will not provide clamping force and can cause major damage to components.
Sugar Bear is offline
Old November 14th, 2023, 09:47 AM
Out of Line, Everytime😉
olds 307 and 403's Avatar
The longer two would be up top, one captures the trans dipstick eyelet. I upgraded to grade 8 bolts, 1.25 and 1.5" 3/8-16 is what I used with lock washers.
olds 307 and 403 is offline
Rvsmith5
July 26th, 2018 06:50 PM
Alex72cutty
September 4th, 2014 04:03 PM
James Wilson
July 30th, 2012 09:42 PM
frasco
January 25th, 2012 03:36 AM
Drivetrain/Differentials
November 14th, 2008 12:00 AM
Quick Reply: Bellhousing bolts?
