Strange Leak
Strange Leak
Chevy TH350, doesn't leak when its running. Only after its off and cools down it leaks out, can't tell if its from the pan gasket or dipstick housing on the tranny. Has this type of leak happened to anyone?
Not on a T350 though I've had T400s do things like that. Usually after the car sat several days.
Could be pan gasket or fill tube o-ring, or shift lever or speedo cable seal. Maybe a front seal that's weeping a little, fluid collecting in the starter cover and then dripping out when car is shut off?
