1954 - 1956 Cowl Tag Decoding - For Review
Old February 13th, 2024, 08:02 AM
madmax442.com
madmax442.com's Avatar
Worked on this off and on for a few months. I used many sources including the original dealer brochures. Been a fun project. Need more sets of eyes on this, please send me comments for typos and/or inaccuracies.
https://www.dropbox.com/scl/fi/b1nee...vc0ukuel9&dl=0
File Type: pdf
madmax442.com is online now
Old February 13th, 2024, 09:51 AM
Excellent document. Nicely done.
This is only a comment on nomenclature. You identified Interior Trim Code (D) & you identified Paint Color Code (E). I understand Interior Trim Code represents both color & fabric.
Under Vehicle Options (F/G) you reference (E) as "exterior paint code":
"If a particular vehicle was to be built with optional equipment, the codes for these extras would be stamped below the exterior paint code."
Perhaps I'm being picky, none-the-less you (instead) might change Paint Color Code (E) to Exterior Paint Color Code.
Under 1955 Olds Paint Color Codes I believe correct formatting is to employ the plural instead of singular. A single body line (singular noun) and a single molding (singular noun); however, both (together) represents the plural and themselves would be correct. Or, changing the construct of the sentence you might reference the singular by stating: "Each body line and each molding lent itself"
"the body lines and moldings lentitself"
Under same section (1955 Olds Paint Color Codes) you state:
"In general, the first code was the low body color which usually included the rear quarter panels and the deck lid." I believe the term "low" should be changed to "lower".
Only suggestions....
Vintage Chief is offline
Old February 13th, 2024, 11:21 AM
madmax442.com
Nice Norm! Thank you for reading thru it! Good points I will fix those.
Old February 13th, 2024, 11:40 AM
madmax442.com
Revision # 2
https://www.dropbox.com/scl/fi/letic...5rkszmdlp&dl=0
Old February 13th, 2024, 12:10 PM
Under 'E' -
Noun verb agreement:
You state: The paint color code were two digit numbers.
The paint color code "is" a two digit number; or, the paint color codes were two digit numbers.
Old February 13th, 2024, 01:21 PM
madmax442.com
Thank you, I was thinking of the paint code as a set of codes, so singular. LOL. I appreciate it.
On a side note. Anyone know what the Option K1 was? Something with the seat?
Old February 13th, 2024, 01:23 PM
I hope Post #5 caught you in time before you finalized your document & moved it over to your website.
I have familiarity with site building, navigation, etc. I could see when you were making changes to the document on Dropbox, I could also see you employed Excel to create your tables. Little tricks. I like your website.
Old February 13th, 2024, 01:26 PM
I can't validate this (K1) information >>>> https://classicoldsmobile.com/forums...-please-66635/
Old February 14th, 2024, 04:16 AM
Tri-Carb's Avatar
Fisher Body Date Plate (1962oldsmobile.com)
By 62 K1 was a padded front seat cushion.
Tri-Carb is offline
Old February 14th, 2024, 09:23 AM
madmax442.com
Yes, thank you. I don't think there was an added option for extra padding on the '55 seats. I can add that to my doc for now, can't hurt until someone cries otherwise. Thanks again for your feedback.
Old February 14th, 2024, 06:53 PM
madmax442.com
My final draft is live on my website and is here now.
Enjoy!
Old February 14th, 2024, 07:12 PM
Looks good. Took me a couple seconds but I figured it out. The lines delineate the 88s, from the Super 88s & the 98 Series.
Old February 14th, 2024, 07:13 PM
madmax442.com
Yes Norm, a few little Easter Eggs in there. Thanks again for proofing!
Livesaint
November 9th, 2022 08:19 AM
oldcutlass
April 14th, 2022 07:27 AM
72455
October 24th, 2021 06:59 PM
rlafash
July 26th, 2016 06:36 AM
rlafash
July 25th, 2016 07:39 AM
Quick Reply: 1954 - 1956 Cowl Tag Decoding - For Review
