‘57 Super 88 Radio Removal
Old April 16th, 2024, 01:43 PM
Hogan's Avatar
Hello. I’m trying to remove the radio so I can get the instrument cluster off of the car in order to finish an upholstery job we’re doing. I’m not having any luck. It’s chrome and I don’t see a set screw so I was just hoping someone could help me figure out how to get this thing off.
Thanks,
Hogan
I removed the panel up until the radio and I can’t get the instrument panel off until the radio piece comes off.
This is the other side of the radio from underneath. I can’t really loosen anything back here and I’m unsure if it’s gonna be alright to unscrew that flathead screw. But it’s the only thing I see that I can do anything with.
Hogan is offline
Old April 16th, 2024, 02:21 PM
You need to remove the ***** and behind them the nuts that hold the radio to the dash. Then slide the radio to the rear until the shafts clear and drop it out.
oldcutlass is online now
Old April 16th, 2024, 02:56 PM
I believe the radio ***** are held to each post w/ a set screw. You may need a fine dental pick and/or a tooth brush to remove ~80 years of dust/grime to view ea. set screw.
Vintage Chief is online now
Old April 16th, 2024, 03:58 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I don't remember any set screws on the 54 I had. It has little springs inside the **** that put pressure against the shaft. Look real close and if you don't find any set screws, you are going to have to pull them off. I suspect they are almost seized onto the shaft as long as they have been on there. Once the ***** are off, it is a piece of cake like Eric described.
redoldsman is offline
Old April 17th, 2024, 11:57 AM
Ah. I know exactly the type you're referring to. You may be right.
Old April 17th, 2024, 02:13 PM
madmax442.com
madmax442.com's Avatar
My '55 had set screws and those little spring washers. I am pretty sure those are there to make sure you don't mount the ***** too tight against the secondary ***** for tone and distance. Once you get the ***** off, it will be straightforward to remove the nuts, the chrome faceplate, then the radio stem nuts.
madmax442.com is online now
Old April 17th, 2024, 04:12 PM
redoldsman's Avatar
If your 55 had set screws, then I am sure the 54 had them also. It has been a long time since I changed the radio.
Old April 18th, 2024, 06:55 AM
ub2693v's Avatar
Looks like you got a huge glove box in 1957!!
ub2693v is offline
Old April 18th, 2024, 11:53 AM
Nomadoc's Avatar
The ***** have set screws
Bill
Nomadoc is offline
ArDan5s7
October 15th, 2018 11:36 AM
davoaz
July 7th, 2014 02:04 AM
Kyle's 77 Cutlass
April 6th, 2014 08:21 AM
ELECMAN
May 29th, 2010 11:04 AM
Joeypete
August 2nd, 2009 08:58 AM
Quick Reply: ‘57 Super 88 Radio Removal
