66 442 heat riser block offs
In a Hemmings mag Dec 2016 I read this article about 66 442 Lancing Lightning that included this "the intake featured a pair of clever exhaust heat-riser block-offs, one on either side of the center carb. The owner could unscrew the block-offs and rotate them 90 degrees, changing from street to strip without disassembling the engine". How does this work?
Depends on the climate, cold weather the heated air beneath the manifold aids in cold starts,choke operation and overall combustion. But if you find the engine will be running hot for most of the time you will be fine with them in the closed position.
So my curiosity got to me and as the article in Hemmings described for racing reinstall the block offs quarter turn to eliminate heating fuel to center carb. When I pulled my block offs noting no gasket and very little gasket maker if any which makes sense that this could be done on a race day and put back easily. Nope. Luckily I got some high heat gasket maker and two sets gaskets on hand. After some clean up I installed a gasket and a bit of Gasket maker on an let marinade over night. Driver side block off leaks. So disassembled and cleaning up a bit more now. Question is metal to metal? Use a gasket? use gasket maker? Just curious to see what works for you all since the article suggest quick change metal to metal.
Heat Riser block offs 1966 442 tri power
I have a 66 442 with tri power that has the heat riser block offs. I understand you can change them to cut off heat to the intake on the middle carb. What is the reason that change should be made? How does that impact performance? I get questions from people all the time about those riser block off and I would like to be able to respond with an intelligent answer
Jim
Jim
Cooler intake air is denser, which makes more power. The exhaust crossover under the carb is intended to warm the incoming air during cold engine operation to promote fuel atomization. Once the engine is warm, it really isn't needed. Blocking off the crossover is primarily used by drag racers who need the last few hundredths of a second in their elapsed times. Blocking the crossover to lower inlet air temp is worthless unless you also rejet the carb to take advantage of the denser inlet air. In any case, you are unlikely to feel any difference on the street.
Jim
Jim
I can see the block offs working for about 10 minutes at the track(which I assume is what they were made for).
But after that, I imagine the manifold gets heat soaked and it wouldn’t matter much.
Am I off with my thinking?
j_link
August 11th, 2013 07:49 AM
