1970 olds cowl tag
Old April 14th, 2016, 12:51 PM
oldsguy23's Avatar
1970 olds cowl tag
hi everyone
I just started working on my olds and i'm a little curious to what the original options were.
Cowl tag reads
ST 70-33678 BF 10873 BDY
TR 940 55 55 PNT
06A 431221 870042
oldsguy23 is offline
Old April 14th, 2016, 01:17 PM
Blackpage's Avatar
1970 Cutlass V8 Hardtop Coupe
Built 1st week of June at Freemont, CA plant
Galleon Gold upper & lower
Black Vinyl Bench Seat
Blackpage is offline
Old April 14th, 2016, 08:16 PM
Randy C.
rcorrigan5's Avatar
For a little more detail...
ST 70 = style/model year = 1970
33678: something is a bit wrong here...should it be 33687? That would decode to...
3 = GM division = Oldsmobile
36 = model series = Cutlass V8
87 = body type = holiday coupe (77 would be sports coupe)
BF = assembly plant = Fremont CA
10873 BDY = Fisher body number (has no relationship to your VIN)
TR 940 = interior color and front seat type = black interior with a bench seat
55 55 PNT = lower and upper body colors = galleon gold for both
06A = time build code = June (06), first week of that month (A), 1970
As I recall, the other numbers are specific to the assembly plant at Fremont and no one seems to have a break for those code numbers.
Your VIN should look like 336870Z------ if you do indeed have a holiday coupe. the dashes simply indicate the 6-digit plant sequential number.
Randy C.
rcorrigan5 is online now
Old July 18th, 2016, 08:33 AM
Toms cutlass's Avatar
Hey Randy,
Can you decode my cowl tag detail?
ST70 34267LAN273574
TR990 14 B BDY PNT
10E
Thank you.
T
Toms cutlass is offline
Old July 18th, 2016, 11:57 AM
ddd777's Avatar
Originally Posted by Toms cutlass
Hey Randy,
ST70 34267LAN273574
TR990 14 B BDY PNT
10E
Thank you.
T
http://v8cars.hu/oldsvin/decode.php
or
http://enthusiast.yearone.com/vehicl...-tag-decoding/
or
http://www.oldsmobility.com/old/vin.htm
or
http://www.oldsmobility.com/oldsmo/v....php?f=12&t=18
ddd777 is offline
Old July 18th, 2016, 12:01 PM
jaunty75's Avatar
70 = model year 1970
3 = Oldsmobile
42 = Cutlass Supreme V-8
67 = convertible
LAN = Lansing assembly plant (sequence number 273574)
TR 990 = black vinyl bench seat
PNT 14 = platinum lower body color
PNT B = black convertible top
10E = built 5th week of October 1969
About the only things you couldn't tell by just looking at the car are the build date and the assembly plant.
jaunty75 is offline
Old July 18th, 2016, 12:44 PM
Thank you! It's not platinum today. Many factory-available options installed too.
Old July 18th, 2016, 02:03 PM
ddd777's Avatar
Question
This car?
http://www.hemmings.com/magazine/hmn...e/3701271.html
ddd777 is offline
Old July 18th, 2016, 02:25 PM
Not that exact car ... this exact car ...
Old July 18th, 2016, 02:35 PM
ddd777's Avatar
nice
ddd777 is offline
Old July 18th, 2016, 03:02 PM
Thank you.
Numerous OEM factory options added, like tilt & sport wheel, 4-way power sport bench seat, dual exhaust with trumpets & cut-out bumper, W-27 differential cover (this was a dealer-only available option), Rally Pac, rear sport suspension sway bar (dealer option), Super Stock II wheels, sport mirrors, convenience group lamps (trunk, underhood, glove compartment, inside rear-view mirror with map lamp), power trunk lid latch, and a custom mod - OEM W-31 aluminum intake manifold. (Cam is mildly performance tuned.) (To do: change axle gear ratio and add anti-spin).
Old December 14th, 2021, 08:26 PM
Cuo17g's Avatar
Decode please anyone
St 70-33677 bf 00252 bdy
tr 337 78 78 pnt
11a 175177. 580036
Cuo17g is offline
ragtopblue
February 18th, 2016 03:14 PM
jimz70
December 8th, 2013 03:24 PM
rjspen
April 20th, 2013 11:29 AM
socalrs
May 24th, 2012 06:38 PM
bjtstarfire
Paint
February 26th, 2009 06:14 PM
Quick Reply: 1970 olds cowl tag
