Opinion 1970 442 spindle defect
Look again. That's the surface where the inner bearing sits. Obviously the inner bearing seized and spun on the spindle. That whole surface looks messed up. Time for a new one.
While the OP asked about the chip, I agree that sometime in the past a bearing had spun on the spindle, granted I'm looking at the picture off my phone. It still looks like it will function fine.
Well, on my monitor, it looks like a weld repair on a section of the journal and the dark area is an unfilled crevice. The wavy line tells me it was welded. If they were radial lines, it would be score marks from the bearing race spinning.
It looks like they welded and machined the weld and blended it where it meets the beginning of the radius and also at an original journal surface.
Almost looks like the bearing was seized on the spindle, then someone busted what was left of bearing off, then took a torch and cut off inner race accidentally knicking spindle with torch. Anyway it's kinda scary. I'll bet if you took a new bearing and slid it on, it will be a loose and sloppy fit. Did you take it apart cuz bearing was noisy? Or just to repack bearings for maintenance?
I'd be getting a new spindle. If it's a manufacturing defect, there may be more. If it's a chip from a busted bearing, it's weak. Plus it probably got really hot if a bearing failed, which would make me wonder if it compromised the integrity.
I would replace it also if you can find a good used or new. With two faults, galling and the torch mark. In a pinch with no choice, I would ***** punch the bearing journal on the shaft
Pat
It does look like the inner bearing spun on the spindle but there should be some evidence of heat staining if that was the case.
But rather than guess through pictures I'd slide the new bearing on the spindle and see if it still fits properly. If its loose the spindle needs replaced. Or better yet measure the OD of the bearing surface with a dial caliper in a few spots and see if its the same as the other side. If there is a huge variation in size I'd replace it.
Again if the inner bearing fits, I'd run it and not think twice.
