My first dumb mistake
Old April 24th, 2024, 10:11 AM
Mikeyt
Mikeyt's Avatar
Had her for 3 whole days.
In the process of cleaning the wiper motor due to it not working I had the Great idea to take the cover off the motor.
Yes the brushes popped out. Yes it looks pretty much impossible to get it back together. Yes I'm sad.
Dangit
Mikeyt is offline
Old April 24th, 2024, 10:16 AM
stan 65 cutlass's Avatar
a lot of motors had small holes for a paperclip size wire, push in the brush, put in the wire to hold it assemble, and pull out the wire to set the brushes
stan 65 cutlass is offline
Old April 24th, 2024, 10:19 AM
Mikeyt
Mikeyt's Avatar
If it don't it will!
Brilliant!
Mikeyt is offline
Old April 24th, 2024, 10:21 AM
Mikeyt
Mikeyt's Avatar
Second mistake was dropping the bearing and watching it roll under my bench and disapppear between wall and concrete floor.
The universe must like me. It was sitting on some debris right at the top of the abyss!
Mikeyt is offline
Old April 24th, 2024, 11:18 AM
Mikeyt
Mikeyt's Avatar
No option to drill a hole.
I do however now have a small piece of bit stuck where the brush slides.
Gonna be an expensive mistake
Mikeyt is offline
Old April 24th, 2024, 12:08 PM
Mikeyt
Mikeyt's Avatar
Blue painters tape, some prayers and lots of luck she is back together!
Hooked to a spare battery and it turned. Now to see if it works in the car.
Mikeyt is offline
Old April 24th, 2024, 12:38 PM
good work Mike, now you learned something about your car
Old April 24th, 2024, 01:23 PM
70W-32's Avatar
Mike, i would buy a Factory Chassis Service Manual for your car, It will have all the instructions for disassembly and reassembly of the individual components for your car. Saves lots of head aches
70W-32 is offline
Old April 24th, 2024, 01:54 PM
Oldsdruid
rocketraider's Avatar
Before you get in too deep you should get the shop manuals as 70W32 suggests. You need the 1961 and 1962 books. These are the same books the Oldsmobile dealer mechanics used to service the cars when new and they're usually pretty easy to find on ebay or amazon. They include all service procedures and color wiring diagrams.
I like to use original printed copies since I've seen omissions and loss of detail in the reprints and especially the CD-ROM and PDF copies.
rocketraider is online now
Old April 24th, 2024, 02:01 PM
Sugar Bear's Avatar
The one that doesn't make mistakes doesn't do anything...keep on truckin'
Sugar Bear is online now
Old April 24th, 2024, 03:14 PM
66_Jetstar's Avatar
The first mistake was buying it!
66_Jetstar is offline
Old April 24th, 2024, 03:33 PM
Mikeyt
Mikeyt's Avatar
🤣🤣Touche
Mikeyt is offline
Old April 24th, 2024, 03:34 PM
Mikeyt
Mikeyt's Avatar
I have the manuals on the way. Should be here Monday.
I get impatient sometimes.
Mikeyt is offline
Old April 24th, 2024, 03:35 PM
Mikeyt
Mikeyt's Avatar
Originally Posted by sugar bear
the one that doesn't make mistakes doesn't do anything...keep on truckin'
Mikeyt is offline
Old April 24th, 2024, 04:49 PM
CH3NO2 LEARN IT BURN IT
droldsmorland's Avatar
At first I thought you got married....whew.
This is how we learn without having to be spoon fed by google.
It was assembled once it will be assembled again.
Here are a few options if you want a full resto on it. Im about ready to send mine out for a rebuild/replating.
https://www.classicwipers.com/
https://dandmrestoration.com/
http://restorationservice.net/?page-id=8
droldsmorland is offline
Old April 24th, 2024, 05:58 PM
dennis_30281's Avatar
If this was your first then you've got a long way to go
dennis_30281 is offline
Old April 24th, 2024, 06:00 PM
Mikeyt
Mikeyt's Avatar
Lol done did that one twice.
Thanks for the links! That's gonna come in very handy!
Got any good radiator rebuilders you recommend?
Mikeyt is offline
Old April 24th, 2024, 06:01 PM
Mikeyt
Mikeyt's Avatar
Only a first for this car. It's only been here 3 days.
ha
Mikeyt is offline
Old April 24th, 2024, 09:23 PM
Talking
Me too. 1st one was for practice. There will be no #3 unless shes filthy rich and 100 years old.
nealcali
November 13th, 2017 07:36 AM
tbristol
July 31st, 2014 06:16 AM
STLCRZY
September 23rd, 2012 12:42 AM
Mikes65
April 16th, 2012 07:09 PM
oldroyale
June 24th, 2009 06:07 PM
Quick Reply: My first dumb mistake
