86' Cutlass Supreme 442 Right Turn Signal
I have a 1986 Cutlass Supreme 442 Coupe with a right turn signal that doesn't work. The problem is that the rear right light doesn't activate when you use the right turn signal, the only thing that happens is that it makes that sound(tick tick tick...) plus the interior right arrow on the speedometer doesn't even light up. I was wondering if anyone has a wiring diagram for the back lights so I can at least distinguish what each wire does in the mean time before I seek professional help. Thanks in advance!
If it's a fast ticking sound and the right front light operates, that would be an indication of burned out bulbs... If you already tried changing the bulbs, then it is possible you have a wire issue, possibly a ground wire....
costpenn
June 24th, 2015 10:38 PM
