1967 CS Holiday Coupe
The original HO 330 in my 67 CS Holiday Coupe has started to smoke (I suspect rings but haven’t compression tested it yet). Anyway, I have a Chevy 350 block that I would like to build up as a 383 stroker to about 450hp. My current setup is original olds 330 with a 2sp Jetaway trans. What kind of mess would I be getting into to drop a Chevy 350 and 4sp auto into this car? What would you suggest for a 4sp auto trans?
Thanks!
Thanks!
If you have to build an engine anyway why not do the 330 instead of turning your Oldsmobile into a Chevelle?
That said just use Chevelle SBC frame pads and modify wiring and other stuff to adapt it to Chevrolet.
A 700 is not going to live behind 450hp without mods. Simple to fix but may not be cheap.
Thanks!
I thought we answered your question in your last thread.
https://classicoldsmobile.com/forums...-trans-150353/
Very true, I already have 1 stupid fast car that I have to be careful with to avoid the local constabulary. I just want to use the Cutlass as a cruiser and daily driver. My daily commute has a max speed of 45 and while I like to stick my foot in it, I don’t need a speed demon. So, what I really want is a good, non smoking, motor with a nice throaty exhaust and I think rebuilding the 330 with better heads is the right direction for me.
