Radiator Fitting?
Old May 18th, 2011, 02:25 PM
smietana's Avatar
Radiator Fitting?
Any body Know what this fitting is on this 71-72 rad?
smietana is offline
Old May 18th, 2011, 03:26 PM
Oldsmaniac's Avatar
I am guessing that is an aftermarket radiator and that port is not needed for a 71 Olds.
Oldsmaniac is online now
Old May 18th, 2011, 04:09 PM
smietana's Avatar
Can it be capped? Should I take it to a rad shop?
smietana is offline
Old May 18th, 2011, 04:26 PM
Does it go into the radiator itself, or into a tube, like the transmission cooler does?
MDchanic is offline
Old May 18th, 2011, 05:49 PM
smietana's Avatar
Right into the tank.
smietana is offline
Old May 18th, 2011, 06:07 PM
cfhcar's Avatar
it can be capped part store should have caps. looks like for heater hose. some cars returned coolant from the heater to the radator
cfhcar is offline
Old May 18th, 2011, 07:08 PM
Agree with all above - it's one of those one-size-fits-all universal application things.
MDchanic is offline
Old May 18th, 2011, 07:31 PM
Oldsdruid
rocketraider's Avatar
Heater return hose fitting. Starting mid-73 they relocated the return port from water pump to radiator cold side tank to reduce heater core nose. Apparently some cars would "gurgle" loud enough to hear inside the car. So you obviously have a "universal" radiator, which generally means it doesn't really fit anything exactly right.
You oughta see the factory "fix" they put out for cars that didn't get the updated design. It was a brass tee that went in the lower radiator hose and routed the heater return hose to that.
You can run your return hose to either this fitting or to the water pump. You'll just have to cap the one not in use. Be careful of those rubber caps. I've seen a lot of them that were thin in spots and would bust under pressure.
rocketraider is online now
Old May 19th, 2011, 02:10 PM
smietana's Avatar
Thanks for all the help, when I get the core support back and mounted will see how it fits.
smietana is offline
olds 307 and 403
April 13th, 2014 09:25 AM
Oldsguy
September 15th, 2008 11:08 AM
bjtstarfire
July 26th, 2008 08:41 AM
68Toro
April 4th, 2008 06:04 PM
Olds Nut
September 18th, 2007 07:10 AM
Quick Reply: Radiator Fitting?
