66' Toro Drums
Old September 21st, 2023, 03:45 PM
ourkid2000's Avatar
66' Toro Drums
Anyone know what color the original 66' drums were on the Toronado? I'm going to have mine off shortly and I'd like to give em a coat of paint
ourkid2000 is offline
Old September 21st, 2023, 05:37 PM
schlitzguzzler1's Avatar
I think mine were argent silver
schlitzguzzler1 is offline
Old September 21st, 2023, 05:51 PM
torotoyguy's Avatar
Per a NOS spare drum as confirmation, they are painted cast iron gray - not black, not silver as I've seen many have done.
Thanks for trying to be authentic.
torotoyguy is offline
Old September 21st, 2023, 06:20 PM
ourkid2000's Avatar
Awesome! Thanks for that!
Old September 21st, 2023, 10:21 PM
cfair's Avatar
I’ve never painted brake drums.
Not to be a doubting Thomas, but with the heating/cooling + expansion & contraction brake drums go through, can paint be expected to stick?Must be special high-temperature paint…
Count me in the ignorant group. How well does paint stick over the long term?
I’m all for aesthetics, but if it’s just going to flake off after a few drives, I’d leave them cast iron/aluminum or whatever - a.k.a. natural
Cheers
Chris
cfair is offline
Old September 21st, 2023, 10:48 PM
OLDSter Ralph's Avatar
"People" have been painting brake drums for decades. The most important is to choose a paint that can stand the heat and CLEAN the area to be cleaned.
OLDSter Ralph is offline
Old September 22nd, 2023, 05:20 AM
ourkid2000's Avatar
Cheers
Chris
Mine were painted some time ago the same color as the body color and I don't really like the way it looks. The body was painted in a silver color that is also not correct and now has to be redone after all these years. So, I was just going to strip them and do them over to the original color.
Old September 22nd, 2023, 03:49 PM
a long time ago an old timer told me to paint my exhaust manifolds with Slip Plate. he said it would keep them a nice grey color. I would think that would work on a brake drum?
Old September 22nd, 2023, 04:47 PM
torotoyguy's Avatar
Years ago when I refreshed my brake drums, I used Eastwood Cast Iron Spray Gray paint - #1258 no longer available, apparently replaced by this:
Old September 22nd, 2023, 05:02 PM
ourkid2000's Avatar
That stuff looks nice. Do you need a primer with that I wonder?
Old September 23rd, 2023, 01:47 PM
torotoyguy's Avatar
This is what I copied from Eastwood website :
We recommend cleaning part with our PRE Painting Prep (10041Z) to remove oils and contaminates. Spray Gray can be applied directly to bare metal surfaces. For better durability, prime with our Self Etching Primer (16014Z) Aerosol, or (16009ZP) Quart. If the metal is rusty, use Eastwood Rust Encapsulator (16060Z) Aerosol. Use these products in a well ventilated area, or use a respirator.
Old September 23rd, 2023, 02:43 PM
I use VHT Ceramic High Temp engine paint. Good for 550F, $12.50 a can
oldcutlass is offline
Old September 25th, 2023, 02:29 PM
torotoyguy's Avatar
Whatever paint you use, it would be interesting to see both before and after pictures.
Old September 25th, 2023, 04:13 PM
ourkid2000's Avatar
I will post some pics here when I get them done. Thanks again for your help!
Old February 24th, 2024, 12:26 PM
I just ran accros the paint code in the 1966 assy manual. "Brake drum outer (Ribbed) surface is to be pained Dk. Gray metallic code 350 (RM E32A002)"
sgolds
February 26th, 2022 02:32 PM
cherokeepeople
April 9th, 2019 08:56 PM
mats
June 4th, 2015 06:07 AM
geckonz08
July 3rd, 2009 11:51 PM
69convertible
December 7th, 2008 07:51 PM
Quick Reply: 66' Toro Drums
