How does one remove headlight bulbs? 66 Toro
I need to change the headlight bulbs. I unscrewed the bezel around them. The bezel is loose, but I can not find a way to remove the bezel to get it out of the way of the bulbs. With the light housing up to the limit seemingly set by a stop screw, the bezel hangs up on the bottom edge. Light down it hangs up on the top edge. Anywhere in middle it seems you can't get it past the bulb. What am I missing? Do I need to disconnect its arm from the lifter actuator? Or run that stop screw in?
Picture just for reference
While you're working to remove the headlight surround, I might suggest placing some heavy fabric or a wet chamois between the surround and the adjacent body to protect the paint (on both) from damage. It's been a long time since I've done any bulb replacements, but as others have said, it's not easy.
