Repair Suggestions
Old December 31st, 2023, 03:04 PM
Jake707's Avatar
Repair Suggestions
So working on my ‘63 f85 to get it air/water tight and after removing the windshield found some rust problems in the bottom windshield track.
Im not exactly sure what it’s supposed to look like so not clear on how bad it is. The car had been painted before I got it but is still a solid 7.5/10 so I don’t want and more importantly can’t afford a full repaint.
Anyone have suggestions on repairs, estimated costs if a shop does it or anything else for this situation? Anyone have pics of a clean intact channel so I can compare to?
Jake707 is offline
Old December 31st, 2023, 03:06 PM
Jake707's Avatar
Second part of video walk theough
File Type: mov
Jake707 is offline
Old December 31st, 2023, 03:07 PM
Jake707's Avatar
Third part of video
File Type: mov
Jake707 is offline
Old December 31st, 2023, 03:13 PM
Proud Viet Nam Veteran
redoldsman's Avatar
Some of the expert body guys will probably speak up. I think the best thing would be to try and find some rust free sheet metal from a dry climate. The Buick Special and Pontiac Tempest may have the same sheet metal. That is some ugly stuff but you should be able to get by without a complete repaint. Good luck with the repairs. You are not the first person to face this.
redoldsman is online now
Old January 1st, 2024, 01:34 AM
There is no easy fix for this, only welding in new metal. The Y-body cars used both gasket-retained and bonded-in windshields, and the pinchweld is different, so if you get metal from a donor car, be sure it's the right one.
joe_padavano is offline
Old January 1st, 2024, 07:40 AM
chopolds's Avatar
Not a difficult fix, IF you have the right tools. Back when I was getting started, I had a 67 Lemans with a completely rotted out rear window channel. Buying a shrinker stretcher, along with a sheet metal brake, is what you need to do this fix. If you're not going to do this work later on, maybe see if you can borrow one, else you'll need someone to do the repair for you. And, yes, it will need to be welded in.
chopolds is offline
Old January 2nd, 2024, 12:52 PM
Jake707's Avatar
Sounds like Ill have to take this into a shop, Im fairly confident creating and welding in new metal is beyond my skill level haha.
Jake707 is offline
Old January 2nd, 2024, 01:02 PM
Rocket Renegade!
Bummer. That's some nasty looking cancer. Best of luck.
BangScreech4-4-2 is online now
Old January 2nd, 2024, 01:03 PM
It's also beyond the skill level of most body shops...
Old January 2nd, 2024, 01:06 PM
redoldsman's Avatar
Probably a good call on your part. Just be sure they know what they are doing.
Old January 2nd, 2024, 01:21 PM
Jake707's Avatar
Joe, you're not helping beat down the shade tree idea of cleaning it up, sealing it and putting as much glue in as it would take haha JK but Id be lying if I said it didnt cross my mind haha
Jake707 is offline
Old January 2nd, 2024, 03:00 PM
Rallye469's Avatar
I know the sell window channel for 64 GM’s…and while I’m positive it’s not a direct match, I wonder if it can be pie cut to fit the earlier window channel.
As far as the gasket style window seal…I’m at a complete loss.
Rallye469 is offline
Old January 2nd, 2024, 03:26 PM
66_Jetstar's Avatar
This is good advice. Buy the HF shrinker/stretcher kit. You can make that channel easily with a piece of 18 gauge metal.
66_Jetstar is offline
Old January 2nd, 2024, 03:33 PM
Jake707's Avatar
How does the 64 channel replacements compare to 63? I doubt they have anything actually marketed to the 63 but if a 64 is the same shape just longer or different curves that might be a good starting point instead of having to fab it up from scratch
Jake707 is offline
Old January 2nd, 2024, 04:24 PM
Rocket Renegade!
Entirely different body and structure between '63 and '64. You might as well try using one from a Ford Fairlane.
Old January 2nd, 2024, 05:27 PM
Eddie Hansen's Avatar
First things first imho
I know your looking at it with all that crud on it, I would get a wire wheel and clean that crud off and see how bad it really is, to be honest I’m only looking at the picture , See if you really need to replace the whole lower channel, then can you weld? And do you have a welder? Chopolds gave good advice on Shrinker and stretcher and a brake this will allow you to make portions of the lower channel , you can make a template from heavy paper or some old file folders , trace the shape , or get a contour gauge from lowes or Home Depot , this is if you want to try and fix it yourself , either way better to clean it first to see exactly what needs to be done . It could even be done a piece at a time do the seat then the side but this is a lot of work but doable in my opinion.
anyway as a caveat I’m not an expert or a professional I’m just a garage guy , wishing you good luck and will be following along
Eddie Hansen is offline
Old January 3rd, 2024, 12:18 AM
Dynoking's Avatar
Eastwood may have an instructional video on channel fabrication and replacement.
Dynoking is offline
Old January 3rd, 2024, 05:42 AM
Andy's Avatar
x 2..if you make a template and take your time you can do it.. is it going to be restoration perfect? Probably not but get rust out, weld in new metal, windshield covers it up. As JP said most body shops don’t have fabricators, just parts replacers.
Andy is offline
Old January 3rd, 2024, 11:14 AM
Jake707's Avatar
Thanks guys. The car is currently at my friends house who has the garage space as mine is full of a bike lift and too dam many harley projects to fit the car in. He's more knowledgeable on hot rod building/repair than I am so it makes the most sense. Ill get over there and knock all the rust/crud off and see how far it goes back and see what all is needed.
Definitely not a resto project, but want to fix it to last and the hardest part is the car was already painted and the color has almost a goldish pearl to it so not an easy color match. This means trying to save the paint as much as possible.
Jake707 is offline
Old January 15th, 2024, 04:41 PM
Horsepower's Avatar
Good luck with your project. I just went through the same thing with the rust. The only savior to mine is a hole new paint job. Keep in mind that welding creates heat and can destroy paint not to mention spark flying around. Be sure to protect your interior. The thing about body shops is most of them won't do that kind of work anymore to busy doing insurance stuff. You might have to find a car builder guy. All I know is rust sucks. Good luck.
Horsepower is offline
Old January 17th, 2024, 09:45 PM
Love1955oldsmobile's Avatar
Clean all of the rust out to clean shiney metal
Use short fiber glass body filler.
No sparks no cutting no welding.
Check drains on corners if any
You can do this yourself with minimum expense and tools
Poor man's solution
My 2 cents worth - keep the change
Ron
Love1955oldsmobile is offline
Old January 18th, 2024, 04:37 PM
Poor man's solution
Ron
The half-fast repair will work fine - until it doesn't...
Old January 18th, 2024, 05:38 PM
Horsepower's Avatar
For sure!
Chuxter
Body work
June 29th, 2023 08:56 PM
travisbeamon
Body work
November 9th, 2019 05:23 AM
TripDeuces
May 18th, 2018 12:04 PM
blunce
Body work
16
November 2nd, 2014 12:02 PM
Tedd Thompson
May 28th, 2012 12:23 PM
Quick Reply: Repair Suggestions
