Correct Bell Housing
Old January 3rd, 2024, 09:55 AM
TOC
TOC's Avatar
As I continue my restoration, I have a question on the bell housing that came with my 66 442 to convert it to a 4 speed. The person I bought the car from had all the parts to convert the car to a 4 Speed, even the Muncie M20. He claims the guy he bought all the parts from said it was from a 65 442. I had the Muncie gone through by a local person who’s been doing it for 45 years. The M20 was from a later model GM/Chevy, may be a 1968. The linkage wasn’t correct, but he had the parts to make it work for my 66.
Now I’m questioning the bell housing because I don’t know if it’s correct or not. The part # on the housing is #9778882. The flywheel is at the machine shop (along with the block) so I can’t question that until I get it back.
Can anyone verify this is the correct bell housing?
Thank in advance…….Tom
TOC is offline
Old January 3rd, 2024, 11:24 AM
Yes, the '882 bellhousing will work fine. Pretty much any BOP bellhousing has the same dimensions, pilot opening diameter, and input shaft length.
joe_padavano is offline
Old January 3rd, 2024, 11:36 AM
66-3X2 442's Avatar
I have a complete correct 66 4 speed shifter and correct linkage/mounting plate for sale if you need one. I have a restored unit and a unrestored unit.
66-3X2 442 is offline
Old January 3rd, 2024, 03:33 PM
TOC
TOC's Avatar
Joe, thanks for clarifying. My next post will be to check on the flywheel when I get it back from the machine shop..
Tom
TOC is offline
Old January 3rd, 2024, 03:40 PM
TOC
TOC's Avatar
Just hade mine gone through and the correct linkage, adapter, shifter changed out to the correct setup for my 66 442.
Thank, Tom
TOC is offline
rktrde303
January 22nd, 2023 01:05 PM
Nilsson
January 23rd, 2015 10:02 PM
ozoneblue
January 23rd, 2011 05:42 PM
ozoneblue
August 21st, 2007 05:59 PM
Quick Reply: Correct Bell Housing
