Relay making Noise
Old April 26th, 2013, 05:25 PM
68Dreams's Avatar
Relay making Noise
I was warming up the car today to take around the block and after.10 minutes or so the relay on the driverside(the one connected to the battery) started making noise. If I take off the battery wire it stops but then I have no power to the car but when I plug it back in it starts making noise again. Did this relay go bad or is it a crossed wire?
68Dreams is offline
Old April 26th, 2013, 05:27 PM
68Dreams's Avatar
relay on driver side
This is the relay on driverside fender
68Dreams is offline
Old April 26th, 2013, 06:16 PM
Unplug the pink/black wire on the bottom of the relay, see if it has power with the key on. I don't have my service manual handy, the green wire is power to the horns, the black wire is the horn signal wire from the horn button and the pink wire is suppose to prevent the buzzer from sounding with the key on.
matt69olds is offline
Old April 26th, 2013, 06:19 PM
Mr. Johnson
rjohnson442's Avatar
Make sure the screw holding it to the fender is tight, it needs to be grounded. And when you say noise is it clicking or a humm?
rjohnson442 is offline
Old April 26th, 2013, 06:36 PM
68Dreams's Avatar
Thanks for the response guys. Its making a humming noise. First I unpluged the wire connected to the battery and it stopped. Then each wire one at a time but still had a humming. Went down to just the battery wire connected and still made noise. No clue
68Dreams is offline
Old April 26th, 2013, 06:47 PM
Mr. Johnson
clean all the contact's make sure its grounded good. smack it around a few times and if its not working. it's not going to.
Old April 26th, 2013, 07:16 PM
68Dreams's Avatar
K will do. If not probably taking down the dash and check every wire possible
68Dreams is offline
Betsyd68
July 26th, 2014 08:52 PM
Charles Ludwick
28
March 7th, 2012 04:45 PM
Railguy
December 12th, 2011 06:38 AM
davisjd77
Alero
July 14th, 2009 04:02 AM
ls442
July 12th, 2009 01:29 PM
Quick Reply: Relay making Noise
