What is making this noise?
I have a stock 1969 Olds 442 with a 400 that just started to recently make this 'clicking' noise. The noise seems to be coming from the front of the engine. I originally thought it may have been the water pump going out. The 'clicking' increases as the RPMs increase. When I'm driving it about 50-55 mph there seems to be no more power after third gear @ about 2,500 RPM. I had sent this video below to my bother and he thought maybe it is a rod bearing. Wanted to hear your thoughts before I start taking it apart...
clicking
No power, clicking from front of engine sounds like fuel pump eccentric/arm issues. I can't say I've seen that in an olds, although I haven't seen a lot of things. Not hard to pull the pump, look through the hole.
After listening to the video I think my original thoughts are very optimistic. Sounds like bearing trouble, although tiny computer speakers don't really tell the story. Best of luck. And don't drive it anywhere. (in the off chance you might)
If the noise doesn't go away after you pull the belts remove the drivers side valve cover see if it broke the rocker girdle..you can see and hear an obvious miss, but the sound resonates to much on video.
