Front fender power antenna
Old September 24th, 2023, 07:28 AM
Rick Petrow's Avatar
Looking to install a power antenna in the right front fender of my ‘69 Cutlass convertible. Just went through a frame-on restoration & forgot about filling the OE antenna hole & replacing the windshield with a ‘70 version that has the antenna in the glass. Realize space is an issue but wondered if anyone has put one in.
Rick Petrow is offline
Old September 24th, 2023, 08:17 AM
You will find that there's a reason why the factory power antenna was in the rear quarter. There isn't room under the fender for the motor on a conventional power antenna. There are vendors who sell a power antenna with a remotely-located motor that will let you mount the motor where there is room.
https://www.retromanufacturing.com/p...-power-antenna
joe_padavano is offline
Old September 24th, 2023, 06:24 PM
As Joe mentioned, you aren’t going to fit a power antenna in the front fender, in the stock location.
What I did on my car was fill the factory antenna hole, and move the antenna forward a couple inches. That’s probably not an option for a finished car, but that’s what I did on mine 25 years ago.
I’ll take a pic of my fender tomorrow if it helps
matt69olds is online now
Frisbee_k9
May 17th, 2020 09:29 AM
1969442W30
October 25th, 2018 04:56 AM
oldzzy
November 6th, 2014 08:55 PM
denf221
April 10th, 2010 03:16 AM
firefrost gold
Hurst/Olds
February 14th, 2010 11:16 AM
Quick Reply: Front fender power antenna
