Looking for a mechanic
Old April 15th, 2024, 09:40 AM
fgeese's Avatar
Hello Everyone,
I had a recent job change, and have to move in a short amount of time. I have a 67 Cutlass Supreme Holiday Coupe, 330 ci/ jetaway trans, that won't start. It ran when I put it away in November. I've tried to troubleshoot the issue, but am running out of time.
I live in Coupeville, WA, on Whidbey Island. If anyone knows of a good mechanic or group with knowledge out here in the PNW, i would appreciate the reference.
fgeese is offline
Old April 15th, 2024, 09:44 AM
Before getting a mechanic, check for fuel and spark, repair for the one missing.
oldcutlass is online now
Old April 15th, 2024, 09:51 AM
fgeese's Avatar
From what I've been able to find, I have spark. I've also had a small flame shoot out of the carb, so I'm guessing I have fuel. This is an original 330 with a quadrajet with ~104k miles. The car it all original other than the seats being rehabbed.
fgeese is offline
Old April 15th, 2024, 10:07 AM
Can you get the engine to snort by adding ether?
Olds64 is online now
Old April 15th, 2024, 10:10 AM
fgeese's Avatar
It used to start fantastic by pushing the gas pedal once to set the "choke", then it would fire right up. Right now, it only comes close to wanting to start by putting the pedal to the floor, regardless of the use of starting fluid.
fgeese is offline
Old April 15th, 2024, 10:16 AM
Do you have a timing light that you can connect to the #1 spark plug wire and have someone crank the engine to see (1) if you have spark and (2) if it's got spark at the right time?
Old April 15th, 2024, 10:28 AM
fgeese's Avatar
I have a timing light, but I don't have a dwell meter. The timing hasn't changed since I drove it last, which should mean it is still in time, but I know something could have changed. I drove this from Pittsburgh PA to Coupeville WA less than 2 years ago. Ran fantastic other than a wheel bearing. I feel like after doing the troubleshooting I have, it could be the carb. Possibly the difference in gas in PA as opposed to WA. I use lead additive as well, since it has the original seats.
fgeese is offline
Old April 15th, 2024, 10:31 AM
Proud Viet Nam Veteran
redoldsman's Avatar
How many miles are on it and do you know if the timing chain has ever been replaced?
redoldsman is offline
Old April 15th, 2024, 10:34 AM
Did you add 5 gallons of fresh gas?
Old April 15th, 2024, 10:56 AM
fgeese's Avatar
When checking the timing, the cut mark on the balancer lined up with TDC on #1 cylinder with both valves closed. Not sure if the timing chain was ever done though. 104,000 miles
fgeese is offline
Old April 15th, 2024, 10:57 AM
fgeese's Avatar
I put a ful tank of gas in it before I parked it in November, so no room for 5 gal of fresh gas.
fgeese is offline
Old April 15th, 2024, 11:03 AM
When mine hasn’t been started for a while, I pour some gas into the float bowl vent tube to fill the bowl. Try it and see if it fires up and runs - take note of everything that happens as it is good diagnostic information to help pinpoint an issue.
Fun71 is offline
Old April 15th, 2024, 11:07 AM
SY2455's Avatar
Remove air cleaner, while looking down the carburetor with the keys in your pocket, operate the throttle at the carburetor and check that the carb is putting gas into the engine. If not your fuel pump might be history or the possibility of a bad gas hose somewhere in the system.
SY2455 is offline
Old April 15th, 2024, 11:41 AM
1arunem's Avatar
Have you checked the spark plugs to be sure they aren't fouled/wet?
1arunem is offline
Old April 15th, 2024, 03:07 PM
fgeese's Avatar
I'll check. I know my in line filter is filling, that's located right before the carb.
fgeese is offline
Old April 15th, 2024, 03:09 PM
fgeese's Avatar
I put new plugs in it, properly gapped.
fgeese is offline
Old April 15th, 2024, 03:18 PM
That’s a good sign.
You said it has points, and I wonder if the contacts might be oxidized / dirty? Since it was running when parked, it should be fairly easy to get it running again. It’s likely something fairly simple.
Fun71 is offline
Old April 15th, 2024, 10:14 PM
twilightblue28A's Avatar
[QUOTE=SY2455;1564725]Remove air cleaner, while looking down the carburetor with the keys in your pocket, operate the throttle at the carburetor and check that the carb /QUOTE]
​​​​​​WHey are the keys in in the pocket?
twilightblue28A is offline
Old April 16th, 2024, 04:00 AM
SY2455's Avatar
[QUOTE=twilightblue28A;1564831]
Years ago while helping someone who had a similar problem. The keys were left in the ignition and a teenager jump into the driver seat and tried to rank the engine. The owner ended up with wake up call when the engine backfired. Funny at the time, however it could have been bad.
SY2455 is offline
Old April 18th, 2024, 05:48 PM
fgeese's Avatar
Thanks for everyone's inputs so far. I have 6 weeks to get my house on the market, sold, and move to PA from WA. I just don't have the time to troubleshoot it. Sometimes you gotta pay the piper. Any shop suggestions in the puget sound area?
fgeese is offline
Old April 24th, 2024, 04:10 AM
rickw30's Avatar
If you have spark and you have fuel in the carb filter, grab a nail file from the wife and give the points a couple of swipes. Pour a little gas down the carb primaries and make sure the choke flap is closed.
rickw30 is online now
babailey
November 22nd, 2023 05:22 PM
Kirdid
April 30th, 2022 09:47 AM
babailey
Non-Olds Engines
November 19th, 2020 07:32 AM
67cutlass67GS
April 17th, 2014 03:14 PM
m1fresh
December 28th, 2011 01:49 PM
Quick Reply: Looking for a mechanic
